Cutty Sark Semi Kit 1/40 Prototype
Currently I am not planning to produce this at any other scale than 1/40, as I said at the start this was a request for a single client and I merely wanted to put it out into the community in case any others wanted it in this scale as well.
To produce this even at 1/48 would involve having to completely redo the 3d model and start from scratch again, not only is it a huge amount of work but I would have to charge my time and make an already expensive semi kit simply too much for most people.
I am happy to do it at 1/40 though, any request, for this please pm from now on as the prototype is finished now and client has the model.
I do want a minimum number of orders to make this viable and this is not the only site I have done a build on for this particular project.
i would be interested
Hello. What is the price of the drawings?
I have not done any drawings to date, and in the short term I can't see myself getting time to do them.
I am going to have to wrap this up as its simply too expensive, and nobody is prepared to pay the price for this as it stands now even with currency rate differences.
I can't do this for less than $2000AU and in reality was going to say $2500AU the material alone is nearly $1000AU once you take into account CNC cutters, timber and high Quality ply, but then I have to factor in the time to stand over and watch and run the CNC which is days, you don't just leave a CNC and walk away.
The only way that this could still be practical is to source the ply yourself at the correct thickness and I send the people Cutting it on the CNC files , that would be the other option I am prepared to do and could be done for a LOT less.
Even this has potential issues as depending on the machine they would need to re path the files for that machine, and I would only be providing the CAD dxf files, and that would take them 3-4 hours to do as well.
I can only provide usable CNC files ready to go for someone with a Stepcraft D840 or bigger as that is what I have used.
That option could be about $200
A few months ago I had a request to design and build a prototype of Semi Kit of this Ship for a client in the UK.
How did I get this job? I worked on this ships restoration in 2010/11 and was tasked with taking all the measurements, scan data and photos of her without planking at times and building a digital model of her exterior and structure to exact as built specifications, the result is like an Anatomy of the ship book.
All the plans that exist today are educated guesses based on crude measurements due to the period or based of earlier plans , so a lot of inherited mistakes have crept into the plans, I have studied all the plans I know of and then tried to wipe all that and start with what is known and verified from the ship, and its really an eye opener as to how much crucial info is off.
The Cutty Sarks hull was laser scanned in 2009 to provide the architects who designed her current enclosure with a firm guide as to her hull form, and when this is rebuilt using naval Architects techniques and lofted in Nurbs software and faired the error is only very small about 10mm at most full size, the only lines plan that has the midship correct for example is C Jordans midship 1922, but even his sheer line is off aft.
The sagging and collapse of Cutty Sarks hull has been factored into this as it was during the restoration.
I could do a whole post on which plans have what issues and back it up with photographic evidence on every count but I am not prepared to do this publicly.
The official Plans from the Cutty Sark .Org are also approximate even by there own admission, they are based on recollections and previous plans.
What surprised me the most is I have owned C Nepean Longridges book most of my life and viewed it as the bible but after working on the ship and measuring it first hand it's far from it, I am perplexed how some of the measurements are so far out, I can only assume some of the things he measured have been replaced to different scantlings from when she was afloat as a training ship.
In saying all of this how many modellers really care about absolute accuracy? and just want to have fun, I personally could not go and spend over $1000 on a kit that has out of scale planking, wrong lines and even the waterline in the wrong place, the AL kit is the worst, it's not on in my opinion.
I am going to do some plans based off the scan and you will be able to see for yourselves. I am just sectioning the scan, no interpretation is required, it's absolute
I am wanting to know if anyone out there is interested in this kit as I plan to do a small run of this.
I will start this blog with images of the CAD model and showing it overlaid over a version of the scan mesh
But first the size of the model and the height relative to a standard sized room
A couple of shots of the cad model and scan overlaid.
And lines compared to the sections of the laser scan.
Hallo @RichardHDunn
Hi Richard,
my "little" Billing Boats Cutty Sark is still on the go - it's a pale imitation of your model!
I was in touch with Kevin at KTL and he suggested to contact you regarding the dimensions of the lower masts. The Billing plans just show all three masts as having the same diameter but I believe the lower masts on the ship all have different diameters? I have tried to find out the information but the numbers are all conflicting: Campbell's plans say Fore & Main are 22", Mizzen 21", another reference says Fore 21", Main 24" and Mizzen 18" and Longridge says Fore/Main 30" and Mizzen 27". Any idea who's right? I may have to head back to Greenwich with my tape measure!
Thanks if you can help, much appreciated, it is detail that would be nice to have correct on the model.
Dom
Hi Richard,
Dom
I am soooo sorry Dom I did not get notified of this message.
Are you all good now?
Hi Richard,
Dom
To set it correct the masts are not the same diameter up the mast.
The size reduces according to rules, I have the plans in my collection but I can tell you the fore mast was 28"3/4 at the deck 24" at the head and 25"5/8 at the heel
The main was 24"1/4 at heel 28"1/4 at deck and 24" at the cap.
I have not come across the mizzen plans yet.
Keep in mind that because they are riveted from 3 sections the diameter will vary depending where you measure, so as long as you are in the ball park.
Henry Henderson wrote is his journal stated 1870 as the ship carpenter the following in regards to lower mast diameters.
Fore - Heel 24, Main deck 28 Hounds 26 and cap 22
Main 24, 28, 26, 22
Mizzen 22, 26, 25, 21
Bowprit 28"
Jibboom cap 24" and 17" at cap
We have found all the mast plans and yards to!!!
Hi Richard, thanks for the info. I was able to find some information on the masts from the Greenwich museum (they went out and measured the lower mast diameters for me!). I have made up all the mast sections accordingly which are " more-or-less" to the correct scale dimensions (good enough for my efforts!). The problem I have at the moment is that the ship sailed into the Doldrums while I tackled a lot of my other summer projects and the build stalled completely. Hopefully, now that the weather has turned here in the UK I will be able to "re-motivate" myself and get back onto the build soon.
Dom.
I can finally advise anyone still watching this that the plans will be coming in a short while and by plans I mean a every little part, I have been picked up by a major publisher and am now under contract to do this as a book covering every single aspect of Cutty Sark's Structure and Rigging.
That's about all I can say at this stage.
Work on this book has been underway for months now already.
Dom.
That's great
None of her spars or masts are original and were replaced with steel in the 1950's and 90,s but They are still close, those measure above were taken in 1870 and are as built
That's a big undertaking! Modellers like me just rely on the Longridge's and Campbell's plans which have there limitations. One thing I have found interesting is how the ship changed over her career. She was a working ship underwent many refits and alterations so for me there is no definitive "Cutty Sark". The changes made to the deck houses and the shape of the forecastle deck are examples that I found, but I am sure there were many others (being cut down and turned into a Barquentine!). Even how she was painted was very interesting research finding all the old historical photographs.
If I was starting again, I would scratch build rather than spend all the time trying to correct all the issues with a kit (but not at 1:40!).
Yeah she sure did and all this and a lot more will be addressed.
I was the same as you, having known the ship my whole life and relying on those 2 sources but once I was involved in the restoration and got the hundreds of measures and the data from Greenwich both are riddled with errors.
The plans from the Cutty Sark are ok but the rigging was the main focus of the plans.
In saying that the mast lengths are not as built and if you look at pics and the plans things like the hawse hole is actually off by one frame and the line of the keelson and its extents is wrong but thats because Campbell did not have access to this info like we do. A large proportion is educated guessing, even the sheer is incorrect.
Longridges book re the hull is full of errors to actually largely because a lot is cases where something is "about 4 feet from" and not specific which really surprised me but unless you actually undertake this sort of project you would miss it. However he was the first to document the ship and although she was nota working clipper by that time its still full of info, mainly for rigging.
