Good morning Adi,
I can only agree with Heinrich, great work on the sail.
Good morning Adi. That is a fine sail. I like the way you did your robands with a reef knot ….very authentic. Cheers GrantThank you all for likes and comments.
The foresail is finally finished and will be installed soon.
Excellent job and great recovery on that problem.Before building the stern I studied several times the quite good explanations of all blog friends who already much further. Especially Uwe's detailed work that ends wih the realization that he has found a way to come to a good result. maybe someone will find another.....
Looking at the CAF build instructions, I noticed that only cradle part A9 is supposed to be enough to build the tail section.
After taking a closer look at all the individual parts and their interaction, I came to the conclusion that this should be possilble.
Set the keel into the base plate, part A9 behind it.....nasty surprise, the tolerance devil has struck.
Doesn't look good, so fill it up.
before...after...
Now prepared the individual parts, with the same realization as Uwe, the center piece will be too wide, so sand evenly.
Next, I temporarily assembled the rear part of the cradle to attach the center section of the stern to the keel using part A9.
Then I realized that laser cut part 12 is flat and not curved like parts 13-1 and 13-2. Then parts 6 and 7 would have to fit neatly and flatly in there to then insert part 13-2. This is exactly how it worked then.
Now the rest almost follows itself. Finally, the "bullhorns" are added. That was a bit tricky, but it worked well and fit.
I think I can be satisfied with the result.
View attachment 205714View attachment 205715
Sorry for noticing your sail works now for the first time, Adi.Thank you all for the likes and comments. The foresail was attached to the mast and fitted with all the necessary running rigging. Next comes the fore topsail.
Hallo Adi mein Freund alias @pianoforteAfter the nice colleagues here persuaded me to start my own log, I decided to do so. After I was impressed by the accuracy of fit of the parts from the beginning, I started to remove the char layer.
Another possibility to grind the stuff gently and carefully was to use an elastic silicone polisher from Proxxon. That really worked.
Of course Iwork on tricky areas, like you do with the needle file.View attachment 184065View attachment 184066View attachment 184067View attachment 184068
