- Sep 3, 2021
I tried to use 0,5mm dia brass, but that doesn't give me a positive fixation possibility. I tried evergreen strip, square 1mm, didn't work, eventually I used 1,2mm wide brass strips, and drilled holes 1,0mm and 0,5mm to align the valve stems, the rocker bolts and the push rods. Given a pitch between the rocker bolts of 1,5mm and tolerances of at best +/-0,1mm and it's easy to see where the issue stems from...I googled the Argus Engine yesterday. And for me the rocker arms are now problems at all, Johan. I think the problem will be to find some material as tiny as it is related in scale. Some smallest needle pins of your Admiral? Or are they already made of them?
(And taking those macro pics doesn't help either... ;-) )
