Nice....good idea to let glue dry with deck in place....I like it
i did some Mish-Mash with my description , i meant that i glued the bulkheads into place ,and the deck pices together not to the skeleton itself .Nice....good idea to let glue dry with deck in place....I like it
I love Lego jigs- use them all the time. I even made a serving “machine” from Lego.LEGO square are the best !
I saw some one made a rope making machine and as well as brainding machine our of Lego.I even made a serving “machine” from Lego.
Good morning. Everything looks spot on and getting ready for some action.
I love that Zion's Zaku...!So no rest for the wicked, my next build will be The Montañés from OcCre.
Will star a full build log here on Labor day May 1st.
Some brief history of the Montañés (Wikipedia):
Montañés (class) was a 74 gun third-rate Spanish ship of the line.
Design was prepared by Julián Martín de Retamosa ,Following José Romero y Fernández de Landa's system under which the San Ildefonso class had been built.
Ordered in November 1792
Launched in November 1794
She was much faster than other ships of the same era, reaching 14 knots downwind and 10 knots upwind.
In 1795 she fought a French force of 8 ships of the line (including one three-decker) and 2 frigates single-handed in the bay of San Feliu de Guíxols - thanks to her superior speed, the Montañés managed to get within range of a coastal artillery battery, forcing the French to break off the chase.In June 1805 she was put under the command of Captain Francisco de Alcedo and made part of Alcalá Galdiano's division, defending Cadiz from a possible British attack. At the Battle of Trafalgar she was assigned to the second division of Gravina's squadron. the ship lost only 20 dead including the capitan and his deputy, and 29 wounded in the battle. And was able to recapture the Santa Ana and Neptuno after their capture by the British.
commanded by José QuevedoThe Montañés took part in the capture of the Rosily Squadron at Cadiz. She also made several voyages to the Canary Islands, Balearics and Havana before being lost in a heavy storm on 10 March 1810.
Spanish ship Montañés (1794) - Wikipedia
en.wikipedia.org
Some illustrations of the Montañés from the naval museum in Madrid
View attachment 437760View attachment 437761View attachment 437762
more decks illustration and purposes can be found here:
¿Cómo es por dentro un navío de línea de 74 cañones? | Todo a babor
¿Quieres saber cómo era por dentro un navío de línea de 74 cañones? Planos detallados del navío Montañés, uno de los mejores de su clase.www.todoababor.es
The kit:
1/70
LENGTH 1250
HEIGHT 895 mm
WIDTH 470 mm
View attachment 437767View attachment 437769View attachment 437771View attachment 437772View attachment 437773
Cheers
Guy
Good morning Guy. First half, 4 butt deck looks great. Cheers GrantView attachment 447286
For the planking i decided to go with 4 butt switch system with length of 70mm planks.
And one half of the waist deck is ready View attachment 447288
And for the rest of the week the 2nd half .
Cheers
Guy
Good afternoon Grant.Good morning Guy. First half, 4 butt deck looks great. Cheers Grant
No real alignment issues so far, I did have to drill out the forward mast hole ever so slightly as it was rubbing on the frame below the first deck... I will do an update later on my thread, but be very careful on gluing the 1st and 2nd gunports. I had to sand a lot of frames to get everything to lay flat and smooth. Today I am going to sand and do some wood filling.....I am assuming the quality of installing the gunports will dictate the quality of the hull planking so I am taking my time.
Your deck is looking very good......
Good evening Guy. There always must be some problem we need go work outGood morning,
So i decided to go with the update now as the wasit deck is finished.
It turned to be very nice so i wanted to share it with you now.
So while i waited to the glue to dry completely i made test run to check
how driling and filling the tree nails witch CA glue simulation will turn out.
I didn't drill all the deck,only the visible area that will be seen after the quarterdeck deck will be lay down.
After i completed to drilling filling and sanding the deck i lay 2 coats of Teak oil leaving the openings untouched so i can glue the greatings more easily.View attachment 447985View attachment 447986
And of course there's must be a problem .
A design flaw !?
@gene438 did you encounter the same alignment problem with deck and foercastle by any chance ?
That's it for now till the next update .
Have a great week.
Guy
Thank you, I'm trying to do my bestGood evening Guy. There always must be some problem we need go work out. Deck looking mighty fine. Cheers Hrant
Good morning Guy. Very nice. I dont put lights in my ship because I will probably get the wiring wrong and burn the ship down
. Cheers Grant
Hi Grant,Good morning Guy. Very nice. I dont put lights in my ship because I will probably get the wiring wrong and burn the ship down. Cheers Grant
What Grant said.Good morning Guy. Very nice. I dont put lights in my ship because I will probably get the wiring wrong and burn the ship down. Cheers Grant
