I love those photos very much! Of course, I saw the models in the build logs, but when our forum members meet each other - this is golden! I am happy for you Johan, Peter, and Henk!!
**VIEW THREAD HERE** |
That’s looking very nice, Johan. I am glad you give the tissue-option a try.This week saw a lot of work on the empennage and a start on the wing.
The covering of the horizontal tail plane was subject to some deliberations. My initial plan was to use Amati cloth, pre-treated with diluted woodglue and stain, followed by bonding to the framework. During our meeting at Henk's place the other week Peter suggested to use tissue paper instead. Initially I was rather anxious of this idea (which was used by Peter on his Bluenose model to make sails), but after dragging my feet for a couple of days, I decided to give it a shot.
I cut and split some tissue, draped it over the horizontal tail and applied the diluted woodglue mix. After having applied two layers of the mix, I painted the tissue twice with Vallejo paint. This gave a rather nice result, so I decided to make the upper- and lower rudder, lo and behold, split rudders are nothing new, and gave those a similar treatment.
The rudders pivot on an axle, which in turn is supported on three points. One of those points is on the rear spar of the horizontal, the other two are above and below the rudders supported by spars coming from the aft fuselage. That whole construction needs to be supported by numerous cables, to provide the necessary stability.
The rudders themselves were made from a tube, dia 1mm and provides the hinge line, also attached to the tube is a cantilever for rudder control, one single rib and two threads on the upper and lower edge of the rudder. That framework again is covered by tissue, folded over the hinge axle, resulting in a double layered skin. Further treatment the same as the horizontal stabilizer.
The lower rudder seems to be a little bit different from the upper rudder. The only reason I came up with to justify this is to have more pitch-up control.
As I mentioned, construction on the wing als started. The wing is of a two spar, multi-rib lay-out, a configuration still in use today, although... Each wing half has four ribs spread out over the span of the wing,which at a later stage will have cables attached to hold up the wing. The other ribs have a very rudimentary aerodynamic shape and will later be covered with one layer of tissue. The four main ribs are soldered to the spars, the others ribs will be bonded with CA adhesive; the rib pitch is too small to solder the ribs.
The two wing halves with the four main ribs are complete, now the process of bonding the form ribs is in progress.
Below a picture, showing the current status. The empennage is 80% complete, with flight control wiring and stability wiring still to be added. Also in this picture the two wing halves, with the start of the installation of the form ribs.
A better view of the upper- and lower rudders.
The Dutch Flying Spider...The tiny little spider got wings.
Thanks Paul.Very nice Johan!
The tissue is a nightmare to work worth, but it definitely pays dividends.That’s looking very nice, Johan. I am glad you give the tissue-option a try.
Very much so, Dan. I think that in those early days of aviation a lot of features were copied from our (feathered) avians.It looks like the frame was designed using actual birds. The tail section especially looks close to that of some fan-shapes you can see in some birds such as a bow tailed grackle.
Thanks, ShotaJohan, I like your project, it's unique!
Baai Baai mooi- Johan. The guys who flew these little planes has some serious courage- they do look like they will just fold in half. Brilliant detail Johan. Cheers GrantThis week saw a lot of work on the empennage and a start on the wing.
Thank you so much, Grant.Baai Baai mooi- Johan. The guys who flew these little planes has some serious courage- they do look like they will just fold in half. Brilliant detail Johan. Cheers Grant
Just a BIG WOW for your fully functional rudder, Johan. A great detail.After hours of fiddling with Serafil, the wires for controlling the rudders and the warping horizontal stabilizer, I now finally have functional, by means of the control stick, control surfaces.
The winghalves are also taking shape, although process is slow. I tried to brass wire types, soft and though, but the tough one is hard to form, whereas the softer brass type deforms too easily. In all, to get nice looking wings is one heck of a challenge.
Stick to the right, rudders to the right:
(Status of the wing can also be seen.)
Stick to the left, rudders to the left:
No worries, Henk, I experience the same with a number of builds I follow. It’s been going on for a while now.Despite the fact that I am on 'follow-up mode', I do not get any notifications via my email, so a late response.
Thanks, gentlemen, it’s appreciated.Nice work Johan,
I heard you before about fat fingers.
There is little to be seen...
I know how incredibly small this is, so there is a lot of appreciation, there is nothing wrong with your fingers.
Regards
Henk
Thanks, Bill.Hello Johan,
Incredible work on your rudder operation and horizontal stabilizer. I can’t wait to see how you will develop the wing warping.
Bill
My experience with tweezers has gone up a notch or two…the details you make with your big fingers, wow.
