Fantastic Grant! Are you just freewheeling those rails? I wouldn't even know where to begin...
Hopefully it’s not a zero-sum game …….. just to hold the zero.So far Justin is in trouble- R0.00.
A very nice scratch build part, Grant, that will always be prominently visible.Beakhead- upper and lower head rail, cheeks and head timbers. The rails and timbers are cut to 2mmx1.5mm.
Good morning Stephan. Thank you very much. I certainly did not intend to when I started however as it progressed that modelling demon grabbed me….Cheers GrantLovely how much efford you put this remake.
Yes he is strongthat modelling demon grabbed me
Good morning Paul. Thank you kindly. More like heading down a mountain pass with no brakes…Fantastic Grant! Are you just freewheeling those rails? I wouldn't even know where to begin...
. An attempt was made to get them as close to the plans I downloaded. An “educated guess” to scale and plank bend. My logic was - if I bent the planks in an exact mirror image for each side and the lengths where the same it should all come together good…..pretty much heading down that mountain passTrue storyYes he is strong
True story .Yes he is strong
Good morning Peter. It has become one……I have become a little determined to win this challenge. I know certain things, E.g dowels for masts and yards, brass sheets and wire will have to be bought. I have all the original kit blocks from my Victory and Xebec and plenty rope. Deadeyes will also be a problem however I am will attempt to make these.Hopefully it’s not a zero-sum game …….. just to hold the zero.
Thank you very much Peter. It came out pretty good and when you view it as part of the whole ships I am very happy.A very nice scratch build part, Grant, that will always be prominently visible
I am a German, so it sounds better, that we lost against the Champion.....Good morning.
To all my Dutch (except for @Peter Voogt) and French friends out there, my Condolences…..Spain and England are through to the Euro finals. Dare I say it - I am an England fan. Cheers Grant
Nicely detailed work, Grant.Good morning.
The base for the fashion piece on the taffrail for the quarter deck cabins with supporting knees.
View attachment 459703View attachment 459704
I cut these out of the walnut ply I made and frame it with veneer which is raised by 0.5mm. I will attempt to make 3D decorations which will fit into this.
Captains entrance to cabin and the cover for the tiller and rudder.
View attachment 459699View attachment 459700View attachment 459701
I struggle with bending 0.5mm wire for the eyelets and rings especially getting them small enough for some scale representation.
…..the face lift continues…
Cheers Grant
Nice....
I like how you work, and the results of your meticulous job, Grant!!
Thank you kindly gentlemen. I did have 3 go’s at the fashion/decoration base. My scratch building is just not up to scratchvery accurate work - very good
Good evening Paul. Thank you very much. I’m not sure if you mean free as in no cost or freewheeling alongAwesome rebuild Grant. No way is this all free...
. My biggest struggle is getting the scale correct. I use the old parts I ripped off as a guide but I have found them, when calculating against the plans I downloaded, to be oversized. I’m no scratch builder……yet, however I am happy how this is going so far. I am learning plenty. Cheers GrantI meant...you are going to lose your bet with your sonThank you kindly gentlemen. I did have 3 go’s at the fashion/decoration base. My scratch building is just not up to scratch
Good evening Paul. Thank you very much. I’m not sure if you mean free as in no cost or freewheeling along. Pretty much both at this stage.
.Not yet….the day is coming tho.I meant...you are going to lose your bet with your son.
