**VIEW THREAD HERE** |
Wow, Henk! You gave that part some Tiffany windows! And that tiny furniture looks fragile and great.Here are a few more photos of the A Deck for the lighting.
What: Verandah & Palm Court with the matching tables and chairs.
Nice addition: the windows.
View attachment 467712View attachment 467714
This is the only room where I have installed transparent windows.The tiny furniture
Amazing work. Thanks for continuing to share your efforts. What type of lighting product are you using for the interiors?And with the lighting
The black of the printer was gone...
Virtually nothing was visible on the floor after installation
Regards
Henk
View attachment 467718View attachment 467719
I did not use the light set from the kitWhat type of lighting product are you using
Thanks Henk.For space I use SMD 0805, Warm white and Yellow
In some spaces I combine both, in some spaces one of the two
In the hull hold I have connected three receivers of the Lutec-Connect brand, one with a light cord of the same brand only for the hull
The lights are dimmable via this system, between 100 and 0%, adjustable between White and Warm white, via Bluetooth via an app on my phone
I already had several groups at my disposal
This weekend I placed a Lutec Cloud Access box in the hold,
with which I can now separately illuminate or dim each space (maximum 50 spaces) on a deck of my choice, which gives an even greater variety of lighting
Here are some screenshots from the manufacturer
Regards
Henk
wonderful work, BravoWithout lighting the deck promenades and the aft deck cabins are not visible, I think illuminating the model gives a nice added value.
Regards
Henk
Here are a few more W.I.P. pictures
All decks have now been glued down, and all lighting has been installed and prepared for, among other things, mast lighting and lighting on the Poopdeck
Boatdeck connects with the height with the installed brass gutters
Lighting has been installed on the underside of A deck and Boatdeck so that the promede decks and the installed spaces with furniture are illuminated
A lot of attention has been paid to concealing the wires of the lighting in the underside of the decks and taking into account the height differences
Standard plastic from all decks on the underside has been removed approx. 0.8 mm in height over the full length of all decks has been sanded down in order to prevent height differences with the Boatdeck
Because the decks became even thinner as a result and lighting has been installed, the pre-drilled cavities of the decks with LED lighting have been covered with silver foil to prevent the light from bleeding through
View attachment 475203View attachment 475204View attachment 475205
Difficult to take some good pictures with lighting, but here is an attempt with my I Phone
What a impressive job, Henk. The invented time in lining out all de decks pays off now. And the lighting with all the pre-work gives a very beautiful outcome. Just GREAT!Without lighting the deck promenades and the aft deck cabins are not visible, I think illuminating the model gives a nice added value.
Regards
Henk
Beautiful job.
Nice job, Henk.
Thank you all for the likes and the nice wordsWhat a impressive job, Henk. The invented time in lining out all de decks pays off now.
Hello Bob,How did you make all the clear windows ?
