You may want to try something like this? They have many others, probably metric also at reasonable prices. Check out Harbor freight also, if there is one near you.
I prefer to sandwich the brass between a couple of pieces of wood then drill the hole instead of using a punch to avoid stress and bending....What do you guys use for a center punch on brass for .1mm holes and smaller
those are nail sets used as countersinks... not center punches.You may want to try something like this? They have many others, probably metric also at reasonable prices. Check out Harbor freight also, if there is one near you.
That sounds like a good idea.I prefer to sandwich the brass between a couple of pieces of wood then drill the hole instead of using a punch to avoid stress and bending....
