Do you drill the hole before? Maybe this is one solution, often it is helping......f.e. If your nail is 0,8mm thick you can use a drill slightly smaller, f.e. 0,7mm. With this the nail should go into the wood without bigger problems.Tnx all. Building empties my head. Its Just the fun of building not the speed.normaly i use powerglue for planking. This is the first time with contact glue and nails. I tried the white wood glue but that makes the wood strips as soft as card board. Destroyed 2 nailpushers already because the nails wont go deep into the wood. Tried several sizes of nails also brass and Iron ones but they all bent when i push. Anyone has the same problem?
This is most important - no hurry - with patience and most important FUNwell done Pat, do it quietly and do not force it, everything will be fine
Greetings
willy
