The little dory with the fragile little parts looks nice, Ted.This isn't as bad as I thought it would be. Still needs some tuning.View attachment 473298
Best regards,
Ted
Best regards,
Ted
Thank you Peter.The little dory with the fragile little parts looks nice, Ted.
Isn't that remarkable. I'm pretty happy too.Hmm, my dories were a mess. I eventually ordered some plastic dories from Billing Boats.
Yours are looking promising.
https://shipsofscale.com/sosforums/...cale-completed-build.6907/page-40#post-328794Much earlier, in someone's build log, I saw that they had made the mast hoops by glueing slivers of wood shaved by a plane into the hoops. See the little pile of shavings I have so far below in the photos.View attachment 473906
I have spent two days searching for this correct build log so I can review and imitate this detail.
Can someone point e to the correct build log?
Best regards
Ted
Another possibility to make mast hoops: https://shipsofscale.com/sosforums/...ogt-completed-build.6566/page-118#post-260825Thank you
To be honest, I didn't even bother using wood curls to fabricate the mast hoops. Instead I followed @Peter Voogt's lead and used a thicker white paper to cut and wind my mast hoops using diluted wood glue and sometimes a touch of CA. Admittedly, that worked surprisingly well.The staining is inconsistent due to the saturation of the pva glue.
The stained and white painted parts show the roughness of construction so I am thinking of painting the parts black.
Any suggestions or recommendations.
Best regards
Ted View attachment 474298
Yours look really good to me.To be honest, I didn't even bother using wood curls to fabricate the mast hoops. Instead I followed @Peter Voogt's lead and used a thicker white paper to cut and wind my mast hoops using diluted wood glue and sometimes a touch of CA. Admittedly, that worked surprisingly well.
Left a higher (2mm) hoop, right the final configuration I used, 1mm high, diameter pending the intended location (lower- or top masts).
The only drawback; you can't put too much tension on the paper hoops, otherwise they deform.
