True story Johan....I dont know if for us mere mortals it is better for it to stay in the peripherals.Exactly, once it's in one's head...
ditto..Every time you post the total picture I am truly amazed what you are able to produce on this scale. Very well done.
True story Johan....I dont know if for us mere mortals it is better for it to stay in the peripherals.![]()
Aha ....... again some 'Brothers in Arms' ........ditto..
Definitely, but it's so tempting to try and do something outside one's comfort zone...dont know if for us mere mortals it is better for it to stay in the peripherals.
True story- so I guess that means you are going for itDefinitely, but it's so tempting to try and do something outside one's comfort zone...
Good morning Peter. It is incredible what you achieve with some innovation and paper “stolen” from the admiral - who would have thought. Your detail on your BN is “off the charts” so to speak. An outstanding BN is being built here. Cheers GrantBefore I can continue with the construction on top of the lower masts, I first had to make the hoops. The main- and top sails are attached to this and thus slide up and down over the masts.
Here's the example in the old photo and the specification drawing in Howard Chapell's book:
Here you are looking at the reefed main sail behind the main mast. (There is a good chance that it will also appear on my BN.)
The kit does not provide these hoops and in terms of desired size I think I can find them somewhere. So got started myself. With the following steps:
1: Selected a nice brown color from my Admiral's scrap-book paper collection. Cut strips of about a mm there.
2: Select a pen with the right diameter. Chapelle writes that the 'hoops' are about a quarter larger than the diameter of the mast. My main boom is 7.6 mm at the bottom. The pin is 9.3mm. So look for other pins for the foremast and upper masts.
Strips cut to length so they can go 3x around the pen.
Secure the first contact point of the 1st round with glue.
3: Always apply a piece of glue and start rolling.
4: Because I glue with wood glue (PVA), the glue remains flexible for a while and I can place the rows nicely on top of each other with a pin set.
5: The end between the points of the picet so that I can clamp it flat in the rest to get a round hoop.
Then this will be the result:
According to L.B. Jenson in The Saga has 36 on the mainmasts, so 18 each. On the uppermasts 24, so 12 each.
He draws fewer in his drawings. But Chapelle writes, "Two or three spare hoops are carried on each mast at the boom.
I have something to do .........
Thanxs, Grant.Good morning Peter. It is incredible what you achieve with some innovation and paper “stolen” from the admiral - who would have thought. Your detail on your BN is “off the charts” so to speak. An outstanding BN is being built here. Cheers Grant
Thanks, Heinrich. But in the meantime I've been busy with fine-tuning.....This is the best of Dutch ingenuity applied to Bluenose.![]()
Thanxs, Jan. And those tiny parts take the most of your time.The beauty is in the details.
Good morning Peter. Only a "like" today no "love"...you have had enoughSometimes you think you're doing the right thing. Until you sort out a few things.
The 18 hoops for the main boom, according to Chapelle, were these dimensions: 24" I.D. x 1 7/8" wide x 1 1/8" thick.
If I translate that to the BN scale of 1:72, then the diameter is correct. But the width and thickness ......... that should then be "as thin as possible" .........
Therefore started again with not 3 rounds but 2:
On the left picture 10 hoops with 2 rounds. But the thickness of the 10 was disappointing: 13 mm. Then 18 becomes a whole stack.
That's why I started again with thinner cut strips.
The result on the right: 10 hoops are 9 mm thick. That's better.
With here the stack of 18 hoops on the deck:
I am satisfied with that. Maybe no spare hoops ........ Then according to Jenson's drawings I can suffice with 15.
That decision will be made when I have the boom and the gaff (with possibly the sail) ready.
For the upper masts I have to look at the 2 turns in proportion. Maybe it will be 1 round there.
To be continued ........
. It good to know even the clever talented modelers make scale dimensional errors. I have been thinking how to make collars for my bowsprit and you have given me the answer...Thank you. Cheers GrantYou are welcome, Grant. You can / may use as much as possible from what I show ……. whatever it is the solution for.Good morning Peter. Only a "like" today no "love"...you have had enough. It good to know even the clever talented modelers make scale dimensional errors. I have been thinking how to make collars for my bowsprit and you have given me the answer...Thank you. Cheers Grant
Thanks, Mark. Indeed: practice, look, compare, re-do, look ........ spot on!Practice makes perfect hey Peter? Those hoops look spot on now![]()
