That is funny, there seem to be more and more kots, but then I'm get much better using tweezers.Seeing clove hitches in your dreams yet Jan?
Lookin' good. H would/will be proud.
I miss H's presence on the forum.
Jan
DittoThat is funny, there seem to be more and more kots, but then I'm get much better using tweezers.
Jan
He's doing a Flying Dutchman; failed to get a pilot into safe harbors (SOS) and is now lost at sea...I miss H's presence on the forum.![]()
Thank you for the quick reply. I think I can manage that.It is done in the same way as you do the rigging of the deadeyes.
Start from an eyelet in the anchor winch, up through the ramshead block, down through one of the holes on the winch, up through the ramshead block, down again and through the winch, up through the ramshead block, and belay on top of the winch.
Hope this is clear for you;-)
Now that's a cryptic message if I ever saw one...And just when you thought it was safe to return to the water ...
Agree. I call that a hit and runNow that's a cryptic message if I ever saw one...
Ah, a voice from the past or just an “ECHO”?And just when you thought it was safe to return to the water ...
I believe that was a carefully crafted reply. Interpretation is everythingAgree. I call that a hit and run![]()
Hello Heinrich, thank you. Your WB logs are a great tutorial. Im delighted that you took the time to check out my WB build.Jan, your build is wonderful - I am indeed very proud of what you have done with the little ship. Seeing your progress for the first time after a long absence has made my day.
True storyAh, a voice from the past or just an “ECHO”?
Good morning Heinrich. So good to see you are alive and kicking. Cheers GrantAnd just when you thought it was safe to return to the water ...
Thank you for checking out my WB build. Heinrich’s post was a pleasant surprise. His two WB builds are a great tutorial. I’ve worked my way through his postings many times.Hello Jan, you have a wonderful WB. I was also happy to see the postings from our friend Heinrich.
