For some reason I am not a fan of making carriages/guns - and rigging them is the absolute worst part of ship modeling.
There. I said it.
Yep! I agree on that one
But you have done a beautiful job on those carriages Paul
     As a way to introduce our brass coins to the community, we will raffle off a free coin during the month of August. Follow link ABOVE for instructions for entering.  |
There. I said it.
Very nice carriages. They look spot on for Armstrong Frederick guns which would be appropriate for 1770.
Those gun carriages!! WOW Paul, as good as I have ever seen.
I now expect nothing less from our very own superhero, ‘Doc Timber’.![]()
Thank you very much, gentlemen. And to many more for the likes.I couldn't agree more. This really looks like a masterwork
Are you going to put some oil to give them a little more intensified color?
Indeed, I believe you are presently in gun making purgatory...(?).Yep! I agree on that one.
Can you explain the process of applying the royal monogram to the barrel or was it part of the CNC machining?
Michael
Please add my name to Michael's!
Thanks for the nice posts guys!Like Michael, I am curious on your technique for adding the Royal Monogram...now that you've shared the results, you have to satiate our curiosity with another post, explaining your technique.
					drydockmodelsandparts.com
				Nothing special here Michael. I used a sharp awl to mark the places to drill - drilled a hole to the precise size of my brass wire - carefully slid the wire into place - and then filed/sanded everything smooth. Unsurprisingly, it took more than 16 attempts to get 16 good trucks (wheels).Also how do you get the wheel pins (not sure of the correct nomenclature) into such small bits of wood with a tight fit and no splitting or damage to the wheel? Please don’t say boxwood?
I am and I think you have chosen the perfect word for the process - purgatoryIndeed, I believe you are presently in gun making purgatory...(?).
Hi PaulAllan, I had to do a bit of research to figure out what carriages would have been like with these lightweight 6 lb. guns. As far as I can tell the carriages were all about the same in design but perhaps a bit smaller as the gun got smaller. Or maybe not...
Thank you for this nice offer, Allan. I'm not quite ready to start incorporating printed items on my builds. I'll get there some day...If you are interested in Armstrong Frederick pattern barrels which would be appropriate for 1770 I can send 3D drawings and the name of a 3D printer that has done great work at very favorable prices. The collection of drawings so far has all the British patterns and calibers from about 1625 to 1810 and a couple Spanish patterns.
Thank you, Sergey!Very well made carriages and guns. Very neat and precise, I like it.
I totally understand and admire your choice. There are other choices that you might find interesting in the future to get the appropriate pattern barrel. There is the possibility of having a master barrel printed and use it to make a plaster mold then cast metal barrels as was done on the actual guns or use the printed master to make a silicone mold and cast resin barrels. This makes every pattern, size, amd scale available. Cast Blomefield pattern barrel pic below. This was before 3D printing was readily available so I made a brass master that had the loop and GR3 badge and then made the mold with it.Thank you for this nice offer, Allan. I'm not quite ready to start incorporating printed items on my builds. I'll get there some day...
Stunningly beautiful workmanship, Paul. Your build is on another level which some of us will never achieve but following you is inspirational.Once again, I seem to be wandering about the ship working randomly on things that need to be accomplished before the forecastle and quarter decks can be permanently installed. This week I worked on gun carriages and guns...
Carriage parts:
For some reason I don't use a lot of jigs - but I chose to for the carriages:
There will only be four guns on the Kingfisher, and they will sit in the waist.
The guns themselves are secondary market CNC brass. I added an insignia and wanted to add a vent field, but I couldn't quite manage it. I my take another run at that (or maybe not):
The finished product:
And now sitting loose on the "deck":
These four guns will be fully rigged so now we wait for boxwood blocks to arrive from Zoly (got my order in before he left for vacation).
There. I said it.
And one leaf pile to rule them all...
Is that like a Ratline Nightmare?Indeed, I believe you are presently in gun making purgatory...(?).
Those are really scary. You wake up in a cold sweat with the blankets twisted around you in a clove hitch knot!Is that like a Ratline Nightmare?
Hmmmmm..................Please Grant, here I thought you being better than this, hiding behind someone else's capabilities...
If I can pull of a POF, you most definitely can.
Good afternoon Paul. Wow,wow,wow.......cannon brilliance. Lovely pics. Cheers GrantOnce again, I seem to be wandering about the ship working randomly on things that need to be accomplished before the forecastle and quarter decks can be permanently installed. This week I worked on gun carriages and guns...
Carriage parts:
There. I said it.
