What color is the USS Constitution deck?
. . . and the thing is how to duplicate this color - I know you can play around with colors such as White, Black, and some other Grays by mixing, or you can buy a Gray color already mixed. However, achieving the "look" of what seems like a "washed worn" look will take a little experimentation.
If anyone can duplicate that, I am surely interested.
If you laid down (painted) the surface with just a gray tone paint, it will look just like that; wood that has been painted flat. Therefore, my thought would lean more toward a "stain".
Any other thoughts ?
I agree, Stain is the way to go. It lets the texture and grain poke through. A very diluted wash of black can also used to bring out the texture after the gray stain provides the color. Do some test on scrap wood and see what looks good to you.
i am looking at a stain. I think it will do a better job. I have already tried with paint and I am in the process of sanding it off because I don't like how it looks.
As I said earlier the deck is weathered gray. Remember, American ships had no
access to teak. White pine was too soft to use. It would quickly produce wear
trout marks in the deck. Many times you would see long leaf pine. Later you would see fir used as decking.
The color of the deck varies with the lighting, weather (wet or dry), and tourist traffic to name a few variables. It ranges from an orangey color in the lightly trafficked areas to flat grey in the heavy traffic areas as well as from board to board. It is distinctly different from the deck below due to exposure to the weather.
ok so there is some of that wood look then. Having never seen the Constitution I have no idea what it looks like other than through photos. This certainly makes things more complicated. I think I am going to stick to that weathered grey look. I wouldn't even know where to start on trying to show a combination of weathered varnish and grey stain look.
Stains found in hardware, paint, and Home improvement stores are really translucent paints. My father used to make his own stains by mixing oil artist colors with linseed oil. A major use is to change the color of light colored woods used for cheap furniture. They, therefore, cloud distinguishing wood features; something that you don’t want to do with a carefully planked deck. The new environmentally friendly stains advertise that they clean up with water so if water is included in the stain’s chemistry it will raise the grain of the wood deck planking.
A better choice would be a Wood Dye. Unlike a stain, the colors of wood dyes are in solution (not suspension). Dyes are, therefore, transparent and they penetrate the wood to color it. They often use alcohol as the thinning agent so will not raise the wood grain. They are available in both wood tones and basic colors so you could mix a wood tone with grey. Look for them online at specialty woodworking stores.
Roger
Oh, come on…let’s be authentic. Plank your deck, then get a tiny holy stone and scrub it got a month. There, that is authentic!
Sorry to post this on two separate threads but...
If you want your deck to have a weathered appearance it might be worth experimenting with this product... https://video.search.yahoo.com/sear...6f023e2d0324b63aa0fc3e15fd0bde10&action=click
I think I will use this photo as my guide. It probably was never wood colored. Is it possible they sealed the wood with the stuff that was used for railway dormers?
The Constitution practicum by Hunt describes an excellent solution to dealing with the deck color.
I was under the impression that the USS Constitution had a wooden color to the deck, but when I look at some photos of it, it looks black. Would black be the correct color?
1. Use a light colored wood for the deck. It will darken naturally with time and exposure to ambient light.
2. Use a sealer such as lacquer (solvent based, NOT water based) diluted about 60% solvent and 40% lacquer. Fill the grain and scrape off any lacquer that is on the surface.
3. Do not stain the deck wood. You can see detail on light colored models. Dark models tend to look like blobs.
4. There is NO one color for any deck.
do you varnish the deck?
You can use varnish on a deck. Some varnishes yellow with time. Like bill36 said, mixing the varnish with solvent lets it soak into the deck, bringing out the color and protecting the wood from the ravages of changing moisture content in the air for many years. Where I live in MN, the air goes from very humid in Summer to bone dry in Winter. That plays havoc on our pegged colonial style wooden chairs, such that the legs fall out every Winter from wood shrinkage. For models, the shrinking/swelling action causes wood joint seams to split after several decades.
If you are new to finishing wood, do a test piece first and see if the results are to your liking.
