It's gonna be a hack of a job to get the seems a proportional width. Other than that it clearly shows the beauty of things to come.
You are right, Johan. This was one of the tests. Last Thursday I was on the original Balder for extra pictures from a lot of details. I now also have more references for the planking. There will definitely be another test. And also another light-cove with other hinges …..
The previous version had some errors and the hinges were too thin. That's why a new version:
Auch, not quite sharp .......... the iPhone is sometimes a bit stubborn ...... With dominant black rivets again.
And provided with 'ochre-yellow' and metal-colored rings:
That's 'size pink'.
If you want to show the details, you get the unforgivable macro shots.
On the model:
I've added the original. The ochre has discolored considerably due to the weather.
With a slightly different view of the hinges:
They now have a bit more body. The galley gets a smaller size spotlight. Maybe the hinges a bit thinner. Then I'll show you some steps during the making.
Of course, there also needs to be ventilation:"
Now I can go back to making the frames for the SB side.
PS a little hour later: I see that I placed the light cove backwards..... Sick
Then another one with some lighting......
Wonderful modeling!
Thanks, Paul. Miracles still happen ........ :)
I like the second version of hinges better... I didn't realize you have such big fingers... ;)
Thanks for your support, Jim. Showing it on one of the finger is in Dutch "een inkoppertje". You can wait for a moment for a reaction ...... ;)
Much better-looking hinges.
You also thanks for this support, Daniel. :)
Nice color) close to me))
Thanks, Sergey. That's the advantage of 'Ochre'. But the 'digital outcome' can be different. ;)
