For the windshield supports you may want to try bare metal foil a kind of adhesive aluminum foil you can cover the whole window with. Burnish it then cut out the foil covering the windows with a sharp scalpel.Well, I'm glad I took the time to mask off the anti-glare areas and spray it out, there's practically no way I could make this be as smooth as it is with a brush. I will need to spray off the quarter sections of the engine cowlings as well.
View attachment 488922View attachment 488923View attachment 488924View attachment 488925
The next trick will be painting the windshields support framework an aluminum color. They made the framework integral with the clear windows. These close ups are very unforgiving, I constantly have to go back and do touch ups where the surfaces get nicked and bumped.
For now, it's back to the pinstriping and more painting.
Thanks for having a look.
Bare-Metal, Detailing Model Cars, Trains, and Aircraft, duplicate chrome on model cars
Bare-Metal® Foil is perfect for duplicating chrome on model cars, model trucks, and model aircraft. Bare-Metal® also looks great on die cast models. You can use Bare-Metal® any place that real metal would add detail to a finished kit. Bare-Metal® Foil is a thin metal foil with a self-adhesive...
					www.bare-metal.com
