- Oct 1, 2023
Good afternoon Ted. Sorry to hear about Rascal. We get so attached to our pets it is always hard when they go. Looking forward to this build. Enjoy and good luck. I had better pop over and catch up your BN build. Cheers GrantI just did my first look through if the kit and am excited at the quality of the materials and plans.
The only thing I find lacking is the instruction booklet. Cliff notes would be more comprehensive.
After the Bluenose I feel up to the task
As an aside I'm a little bit snockered right now. Just prior to picking up the kit I had to send my doggie Rascal to doggy heaven. He was diagnosed with lymphoma two weeks ago and started going downhill the last three days. It's such an aggressive cancer and I didn't want him to be in pain and suffer. This kit will be dedicated to our little Rascal.
God bless us all
Ted
Thank you Grant.Good afternoon Ted. Sorry to hear about Rascal. We get so attached to our pets it is always hard when they go. Looking forward to this build. Enjoy and good luck. I had better pop over and catch up your BN build. Cheers Grant
Good morning Ted. Those Caldercraft ropes look pretty decent as far as “kit ropes” go. I don’t have experience with Caldercraft ropes however from the photos there is a big difference from the quality ropes you can buy from ropes of scale or Drydock models. My experience using good quality ropes vs kit ropes :
1. Scale. Most kits do not give sufficient variants for proper scale. If you buy “aftermarket” you have the ability to check the scale and buy any size thread you need
2. Accuracy. Ropes of scale make ropes with the weave turning the correct way and give a way more accurate appearance.
3. Detail. The quality ropes give a way more defined finish especially with served lines and seizing etc.
4. Fluffing. Very little
5. Usability. It makes rigging so much easier using quality rope. This sounds weird however everything just works better. (Well for me anyway)
6. Your finished model is visually improved with the aftermarket ropes. In my case I need all the help I can get and this goes a long way.
Apologies for the long post but this is a subject close to my heart at present. I used Drydock models rope (cotton) on my Xebec (was so cool) and currently I am attempting to rig my Bounty with left over kit ropes and the fun index is noticeable. Visually the difference is off the charts.
The downside- the aftermarket ropes are expensive- especially for me getting these to SA with duties and courier costs.
Lastly have a look at Peters (@Ptèr ) Xebe Grant
Your preaching to the choir Grantc. I think he used Ropes of scale product. You will see how beautiful these ropes are.
Cheers Grant
Lastly have a look at Peters (@Ptèr ) Xebec. I think he used Ropes of scale product. You will see how beautiful these ropes are.
Cheers Grant
www.zoicpalaeotech.co.uk
Surprisingly, it is used extensively by Paleontologist when working with fossilized bones. It glued them together or protects the surface during etching and sandblasting.I came across mention of an interesting material in an old post by a museum conservator working on a Maltese galleon model. It is sold as crystals which can be dissolved in various solvents. The conservator liked it because it is reversible, but the article mentions that depending on the strength of the mix is can be soft or hard when dry. I wonder if this would be useful for de-fluffing rigging threads without attracting dust?-
Paraloid B-72 | Conservation Acrylic Resin
Paraloid B-72 is a conservation-grade material that is widely used due to its transparent, flexible and reversible properties. It is non-yellowing over time. It essentially 'plasticises' a rock or fossil as it penetrates. It is ideal for fossil preparation as it is an excellent consolidant and...www.zoicpalaeotech.co.uk
I have soaked plywood bulwarks before on my HMS Fly. I dug up this old picture.The keel has a few s curves. Would it help to dampen the plywood and clamp it down between two glass plates? @Daniel20
I don't see anyway around trying it. The last thing I need is a twisted keel/hull assembly.I have soaked plywood bulwarks before on my HMS Fly. I dug up this old picture.View attachment 495020
I would think soaking then flattening between plates would work ok, never tried like that Ted.
Thanks Ted, actually I finished that ship in April of 2021. At the bottom of this post and all my post you can click on the links in blue to see my build portfolio.Btw your Fly is coming along beautifully.
