- Jun 17, 2021
I used CA in the same way over a lot of years and nothing has fallen apart yet. UV light is probably the most damaging. Keeping these models out of direct light is probably the best anyone can do. The CA thing alone probably won't do much that we'll ever live to see, provided the models are kept away from heat/UV light sources.
) No instructions wait to remove char until assemble save for a top piece with a starfish shaped cutout. This piece will split if you don't file off this char before trying to fit it over the five little tabs it rests on! Other wise the pieces need th snug fit provided by the char. It is not too onerous a chore to clean the capstan up after assembly. I finished with a little diluted amber shellac brushed on. A very nice solution to a very fussy problem, especially at 1:96 scale! Thanks, Zolly! BTW you will need to open up the hole for the dowel with a rat tail jeweler's file. Cut the dowel to size off the model, then glue it in place.
