Lovely anchor Paul.
You keep on delivering inspirational craftsmanship.
Thank you for posting.
Michael
Michael
Good afternoon Paul. I love the detail of the tapered split. This is the first anchor on a model I have seen done this way - excellent. Your blackened colour is so cool as well. Cheers GrantThe smallest of updates... an anchor:
It would seem that I am the only builder on the planet who cannot wrap the ring of an anchor with rope well. I'm now 0 for 2:
Mr. Antscherl (The Fully Framed Model book series) argues that there should be a tapered split between the two halves of the anchor stock for water drainage. Makes perfect sense to me so I did it...
Parting shots:
Thanks for the visit!
Thank you, Roger!You call it a small update but it's a big outcome. A beautiful anchor and the split stock adds another level of the attention to detail you are so good at.
Thanks, Greg!wow! your attention to detail is amazing. Really does look brilliant!
Much appreciated, Christian!Really precise work. The anchor is looking great.
Thanks, Brad. I did manage to take something that should have been simple and turn it into a project thoughYou say:
"The smallest of updates... an anchor:"
Not only a master of wood and metal working, but A MASTER OF UNDERSTATEMENT also!!
Not simply an anchor, but a custom, handcrafted and highly accurate work of art. I am particularly impressed by the "split" for water drainage. Never would have thought...
Well done!
.Thank you very much, Mirek.Witaj
Zgadzam się z kolegami świetnie zrobiona kotwica Pawle .Pozdrawiam Mirek
Hello
I agree with my colleagues, the anchor is very well made, Paweł. Best regards, Mirek
Thanks, Tobias! The learning continues...Good morning Paul,
your anchor turned out perfect. I'm really impressed.
Thank you, Stephan!Perfect little anchor.
Hi Peter. Thanks for the nice post. I have started using a pickling solution before 'blackening' brass and I'm very happy with the results so far.The smaller the update the greater the reactions…….
The ‘blackening’ of the brass came out very well, Paul. A nice deep soft coloring.
A split part is most of the time a reason for a big shout AUCH. Now its a big shout WOW. A nice detail. I suppose we will see this soon on more models ….
Thank you, Michael!Lovely anchor Paul.
Michael
Thanks, Herman. Yes, the close-up photos betray the real size.Perfect anchor. Looking at all the details you forget the tiny size of it.
Thank you very much, Nigel!Sublime work Paul![]()
Hmm, but how is the prewrapped round bar stock then cut without losing everything?Check this out for doing the anchor ring ... ;-) There is optimisation possible
Apart from that, I don't have any more words to say about this great building anyway :-D
Dirk
Thanks, Grant. I have not seen this elsewhere either. Antscherl writes with a particular authority such that I find I rarely question him...Good afternoon Paul. I love the detail of the tapered split. This is the first anchor on a model I have seen done this way - excellent. Your blackened colour is so cool as well. Cheers Grant
Thank you kindly, Daniel!You never fail to impress Paul. We get to see amazing craftsmanship and learn new information about ordinary equipment. Thank you!
Paul! Perhaps inappropriately, I look at your work and say to myself: "Good Lord." Absolutely outstanding!Well, it wasn't as difficult as I had feared...
The challenge with the cathead supporter and its associated short rail (eking rail) was that these structures needed to be contoured to follow the curves of the hull both vertically and horizontally - at the same time. The cathead supporter also had to be joined to the eking rail via a scarf joint; but that joint was vertical rather than horizontal and I believe that was easier to accomplish and made the fabrication 'doable' rather than 'breathtakingly difficult.'
During fabrication:
Prior to installation:
And now in place:
The current status of things:
I would estimate that I'm 75% done with the headworks with most of the really difficult parts behind me (not counting the figurehead, that is). Slowly, slowly, catchee monkey...
I'd add that you should never touch what you're blackening with bare fingers. Invest in latex or nitrile gloves. If you don't add finger oil, you won't have to clean it offIf you do get some, the key is prepping the metal well. If you don't, it will peal, scale or blotch. First very fine sandpaper, then a degreaser of some sort.
The key is in the prep work!
Paul, maybe it's just me, but I can't understand how you accomplish the precision and crispness of your finished parts! WOW!Before moving toward the waist of the ship, I discovered one more obligation for the forward end: the fish davit and the fish davit cleat (saddle). The fish davit is used as a crane to lift the crown end of the anchor. Around the time of the Kingfisher (according to Lees) there was a transition to a shorter spar fitted to the channel - but Antscherl argues for the larger timber on Swan Class ships and who am I to question that conclusion.
The fish davit:
A hand rope is fixed to each side of the fish davit with eyestrops:
The fish davit will need a metal ring on the forecastle deck, but that remains to be fabricated. In the image below you can appreciate the substantial size of the fish davit (it's as long as the extreme breadth of the ship itself):
Here is the fish davit cleat (saddle):
In association with the fixed gangway there is a ladder and a handrail. The ladder is made more complicated by the fact that its stiles are not parallel with one another. I was able to measure one side and came up with a 30-degree angle - I estimated the other side (27.5 degrees):
And now the guard rail...this was made more complicated by the horizontal 'offset' in the wooden rail, as well as in the corresponding iron strap that connects the rail to the forecastle breastwork:
Thank you for visiting my Kingfisher build report.
I'm still having a blast working on this challenging model- I hope you are enjoying this build as well.
Gorgeous, Paul! How many times into the Casey's to achieve this beautiful coloring?The smallest of updates... an anchor:
Parting shots:
Blessings.
Chuck
Thank you for all the likes and the nice posts, Chuck! I believe the precision can be attributed to the boxwood and larger than normal scale.Gorgeous, Paul! How many times into the Casey's to achieve this beautiful coloring?
I think Peter's quote of Pippi (presumably Longstocking) deserves emphasis. “I have never tried that before, so I think I should definitely be able to do that.” This is core sentiment of not only audacity but of a hopeful vision. There is no self doubt or, importantly, pridefulness. At least that's my interpretation. Thank you for the quote, Peter! Thank you all, and especially you Paul, for the hope and inspiration.I must say that this went very well with your brass work, Paul. A very good looking anchor. Like the former mentioned Pippi quote: “I have never tried that before, so I think I should definitely be able to do that.” And it’s true again, just do it!
The blackened chains are nicely lined and gives some extra contrasts and dimensions on the model.
