My wife demanded the same after anatomy lab...When I came back from submarine trips, my wife made me undress and put my clothes in a plastic bag on the back porch, then straight to the shower.
							|  | As a way to introduce our brass coins to the community, we will raffle off a free coin during the month of August. Follow link ABOVE for instructions for entering. |  |
Thanks for your thoughts, Brad. I remember my grandfather coming home from work in the herring coop, having to take off his clothes in the courtyard behind the house and then wash himself first.A thin skeleton is becoming a strong and rigid fishing boat, ready for the "abundant catch" to which you refer!
Your diligent research paid off! Those fishermen sure went the extra mile to make every inch capable of holding the money-making herring.
I can't imagine how crowded it would be with all those barrels...and the smell, once the catch was in. Good thing the nose becomes accustomed to odors after being exposed to them for prolonged periods!!! When I came back from submarine trips, my wife made me undress and put my clothes in a plastic bag on the back porch, then straight to the shower. I'm sure the fisher-wives did the same.
The nets look great too!
)Hi Roger. Thanks you very much for spending your time to catch up on where we are nowadays and to write this very nice post.I just spent a pleasant part of my afternoon today reading back a few pages to remind myself and catch up on your superb build Peter. I read from “the damage” to your latest post. It really is a terrific, informative and visually appealing build. I am not at all surprised the Friends of Museum Vlaardingen magazine “De Spil” want to write an article on your build, you deserve the recognition.
Thanks, Heinrich. A bit in style of the BN ......... but different.Absolutely beautiful, Peter.
I suppose that there was something of logic. Perhaps hold by hold ..... It's quite an achievement to 'manage' 450 to 500 barrels. As far as they knew about those ‘management’ terms back then.Can you imagine the logistical nightmare of retrieving and storing all those barrels on a regular basis?
Thanks, Christian. Steady working to the aft and then back to the front.Really wonderful progress, Peter
Those barrels in their holds drive home the cramped space being available on these ships. Accidents waiting to happen...The cooperage has brought another supply of barrels:
A little over 100! With the 5 barrels in front, they show which 3 layers were needed to get a nice cover. Whereby the seams between the staves are also accentuated in the 3rd layer. Then the hoops are made black.
The 9 holds filled with the increasing and decreasing number of layers of barrels:
Perhaps the 9th hold will get a 2nd layer.
With an overview of the current state:
Now I can work on the rear with the stay and the compartment for the Donkey steam kettle and coal shed. That is a bit more complex with all its curves than the forecastle.
Ha Peter,For the stern I first have to make the floor. But then I have to determine the position of the mizzen mast.
In the Amsterdam restoration book there is a nice photo on page 70:
With the side note: "Situation in the stern seen from front to back after the demolition of the afterdeck. The mizzen mast was in a steel construction."
It is also mentioned that the mizzen mast had a diameter of 33 cm. That becomes 6.6 mm for my model.
In order to make the mast in one piece with the flat transition on the sides from the square bottom to the round of the mast above, I had to make that from a thicker piece of round wood.
That's Pythagoras, see the insert on the bottom right: 6.6 squared x 2 and the square root of that. That gives you 9.34 mm. I used a piece of beech of 10 cm.
-the 4 dark grey corners around the white circle form the square mast foot.
-the 4 light grey areas are the parts that you have to remove from the piece of round wood to make the square mast foot. Then you can turn the mast further above the square part to the desired thickness of 6.6 mm.
In order to align everything and not be hindered by the length of the mast, I first made a mast stump:
Above the deck you can still see the original thickness of 10 mm.
With the collar at the foot where the mast foot will be placed:
Now that this is in position I could cut the floor beams to size between the iron profiles.
Always checked that everything is still in line:
The mast will later be placed on this way in the port side part:
Just like the pieces of floor in the forecastle, the mast collar slides just over the corresponding part on the starboard side.
Thank you very much, Johann. Much appreciated!Phantastic work and wonderfull modell!
That’s right, Johan. And no insurance……Those barrels in their holds drive home the cramped space being available on these ships. Accidents waiting to happen...
Hi Johan. Thanks for this content post! It’s the perspective. It’s standing on horizontal parts of 2 frames.Ha Peter,
I'm not going to say how impressive your work is (guess I did just that), but I'm a bit intrigued by the mizzen mast foot.
From the picture you refer to from the Amsterdam reastauration book and also the cross sectional drawing in post #232 I deduced that the mizzen mast's center is sitting right on top of a double frame. Your model appears to show the center of the mast to be located in between two frames. Is it the perspective in your picture putting me on the wrong footing?
Johan
Thanks, Jack. No idea if those ‘Vlaardinger’ fisherman did that …..Hi Peter, fantastic job, and lots of sneaky little hiding places, very hand for little bit of smuggling on the side!
Cheers JJ..
