Thanks, Brad. Not like in the high Alps, but they have neatly prepared the slopes. It’s great fun for some ‘in between’ days.Enjoy the skiing!
That's what I was looking for; I think the mast should be supported by the keel somehow, so those reinforcements do make sense.When demolishing and taking that old photo it turned out that there were still some 'reinforcement' beams attached there.
Hi Maarten. Only Monday was a bit busy with long-weekend people. Yesterday a lot of slopes almost for us alone. And some new snow during the night.Hi Peter, enjoy Winterberg, allways fun and hopefully not too busy.
I was in La Plagne last week, fantastic weather and snow conditions.
Only on our way over there somebody threw a pebble on the road with big delays as a result. Luckily no casualties.
Hope you don't have that in Winterberg.
I really enjoy the first photo…. Fantastic.After a somewhat larger step, such as aligning the slightly curved floor over several frames, it is advisable to check whether everything is still straight, flat and rounded:
It still is! Although the iPhone took a slightly distorted photo .....
And then it is also nice to hold your creation in your hand:
Always good for a reference in terms of size.
The first wall to make to size is the separation of the coal shed:
I made it blue on the drawing. In the model, the paper template between the 2 white arrows. From the rectangular deck opening, the stairs lead down along the wall to (partly) the floor.
From the side:
The wall runs diagonally upwards to the back over the arched frames.
Then first plank the triangle up to the white line. The side wall for the cage comes on that white line.
It remains remarkable that those curved lines still end up straight somewhere.
Your are right about the notches, Dean. Although it is not really necessary here in the aft. This room will get a ceiling so that the finish between the deck beams will no longer be visible. Now I could glue small blocks on the underside of those deck beams to let the wall lean against.Looks great Peter! I see the walls are notched to fit the angles above. We trust your walls are straight and square.![]()
Thanks, Grant. In front of the camera she is a real model. Willing to show her curves ………..I really enjoy the first photo…. Fantastic.
Thanks for this nice words and compliment, Tobias. When working on a compartment and showing that part, she is growing out of dimension. Then it’s good to show her from time to time with some reference in scale.Hello Peter, Wow Wow and wow again. It looks simply fantastic. I am personally impressed by the picture of your Balder in your hand.
And he's at it again!Just an intermezzo to try something out.
Behind the long wall is the coal shed. In the room where the Donkey steam boiler is located there is no space to shovel the coal out of the shed.
Therefore in the corner on the other side of the wall:
A frame and drawer made of thin copper foil. At the back a tray so that some coal can also be seen in the opening.
Of course the flat shovel hanging next.
Thanks for your nice comment and compliments, Johann. Still a lot in mind ……Hello Peter,
This will be an extraordinary and wonderful model.
Well built with interesting details.
Thanks, Brad. If needed they have to keep the fire on …….Perfect addition that adds interest and realism!!
