The carpenters have been working hard the past few days:
-installed ceiling in the living area;
-finished beams in the stairwell and Donkey area;
-placed stairs;
-made table;
-provided the bunk with a floor and finished the wall;
-placed various skirting boards and moldings:
This gives you a view of the ceiling, the beams, with the table and the stairs.
From a more normal perspective:
As can be seen in the old photo posted earlier, you can walk around the table via the starboard side. On the port side, you slide behind the fixed part via the bench. If necessary, the starboard part can be folded up.
The rear wall can just be seen in the opening of the cage. The mattress has also been placed.
The hinged part can also be folded out:
A slide under the top ensures that the part does not fold back.
The mast foot was also treated. This gives a nice colour accent, together with the table and the stairs.
So, inside almost done ..... :)
Beautiful! The thing about this kind of detail is that you get sucked into the model. So much to discover!
Thanks, Marco. I also look back regularly.;) I have also provided the forepeak of the bunk with a mattress. Both stove also need to be made for that room. And of course the Donkey boiler. But I think I will make that in between.
Fantastic details Peter, especially the folding table. Love it.
Thanks, Maarten. My BN has also such a table, but was that foldable …… :rolleyes: That certainly had to be the case with this one.
And have to make another extra hole in my template when she has to lie on her side again. For the remaining hull plates and the construction of the bulwark.
But first I have to plank the deck. To be able to put clamps on both sides around the deck beams.
Again looking ahead to see which steps have to be taken first.
Regards,Peter
-placed stairs;
-made table;
Good evening Peter. Wonderful details as always Peter. Cheers Grant
The last hold at the rear also provided with a floor:
Then the construction in this part is technically ready:
Time for some extra photos.
The open construction starboard part in place. Put a little more in the daylight with a different color background.
With a slightly higher position.
With the divided hull, again on the studio table.:
Also with a slightly higher position here too:
I will now first start with the construction of the bulwark on the open starboard part. Then hopefully her complete line will finally come into view.
Wow Peter. What an amazing model. Those split photos are so cool. Cheers Grant
Stunning work, and equally stunning presentation!
I couldn't express it better than Paul and Grant. Spot on! Thumbsup :D
Pete
No words, just...First Place Metal
Ouch...Steph @Steef66 just took my words!!
I'm speechless as I have no words, Peter! I just love your model and the way she is presented.
Thanks, Grant / Paul / Pete / Stephan / Jim. The split allows me to create new creative photos.
And a thank you for all the visitors and the 'likes' during this 1.5 years of building. I had this in mind at the beginning, but that this is now there .......:) For now I can still move forward, many challenges ahead.
Wow! This is really impressive Peter! I just love how the frame really defines the shape of the hull and at the same time allows you to see inside, even when not split. But this is the best type of split, being two equal halves that showcase the entire ship top to bottom. ;)
Thanks, Dean. To be honest, this (till now) is beyond my expectations when I started, but it gives me great satisfaction to face the many challenges ahead.
Started working on the bulwark.
The inside is supported by plates placed at an angle with a piece of round iron on the side:
About halfway there is a rod running through it over almost the entire length. In the top part it is riveted to the plate of the bulwark with a piece of angle profile.
The inside of the aft is more complex to make:
Halfway in the curve there is an intermediate floor or bench. See between the 2 white arrows.
Top left a detail from behind the sloop. The ribs run through that plate.
I have a print of the line drawing, which was my starting point when drawing in Fushion, cut out on the length of the center line and on the outside on that of the bulwark so that I got a template:
I have tilted the photo itself, but the starboard part is lying on its side on the construction board where a print of the line drawing has been glued from the beginning. I could now place the newly printed template on the line of the bulwark so that I had the curve of the sheer in it and the distance to the deck.
In between, the more or less upright supports were made with the intermediate rod. It now looks like a railing, but see the 1st photo of this post.
On the back you can see the 3 now still too long supports that come into the curve.
With the help of the template I was able to cut these 3 to length and at the right angle:
Always a small piece off until they just disappear behind the template.
It took 4 templates before I had the shape of the intermediate floor:
Whereby the 3 supports run through the plate at the right angle and curve.
On the 2nd photo of the post you can see that the intermediate floor is made of tear plate. In my stock I still had model tear plate:
Both of styrene and thin aluminum. It will be the thin aluminum. The systyrene is too coarse with its thickness of 1.5 mm and double tear.
The next step is to make the cover profile on the bulwark. A combination of 2 Evergreen strips, in the correct curve of the sheer and the curve of the outside. For now still a while to go.
