After my post last Tuesday (#1351) and the mention of the empty hold between wall 9 and the watertight bulkhead 10, there was a little voice in the back of my head that told me: something is not right here.
In such a lugger of limited dimensions, every bit of space is used. And somewhere I had also read something about that part on either side of the kossing.
So I started reading both restoration books again because the old drawings did not provide any answers.
With the result in the Amsterdam book on p. 24:
"The length of a tier hold (note: barrel hold) on the Balder was 800 to 850 mm internally, so that a barrel always fitted in there. The hatch opening was 760 mm long and 600 mm wide. The double tier hold (the first hold) had a length of 1520 mm. So two barrels could lie behind each other here. This was done so as not to weaken the connection of the ship at the location of the mast tube with an extra hatch opening in the deck."
I got to work on that by first removing that wall again. The planks were slid out of the profiles one by one. I can reuse them again.;)
I tried out with the help of some barrels whether the dimensions were correct:
And immediately got to work to try out what I had in mind to prevent the barrels from rolling out of my model: The beams in the lengthwise direction between the U-profiles.
At the height of the 'belly' of each row of barrels, such a beam is placed. That beam rests on 2 small knees that are fitted in both U-profiles. I cut them from the 1.5 x 1.5 mm L-profile and are less than 1 mm thick. The beams are 1.15 x 0.9 mm.
Is that strong enough to hold such a row of barrels?
Remember that in the ship, the barrels are loaded on both sides and therefore roll against each other. In reality, there were bulkheads placed in the middle in the lengthwise direction. But then you can no longer see my barrels ........ A bit of FI .....:)
Here is the sketch of how the barrels were stacked and are positioned per row:
More reinforcement beams are drawn on the drawing. I do 1 per row. There are 5 beams in the other holds.
As you can see in de 1st picture under the sloping part of the kossing, 3 rows of barrels would have free space. The 4th one is already resting against the kossing. I left that out to keep a bit of a view inside.
And indeed: exactly 2 barrels fit in that hold one after the other.
The dimensions of the old drawing are correct and did I build that correctly.:)
The front row rests against the metal part that supports the kossing and mast tube.
I don't think this is a Re-Do? It's an adjustment. That saves me a coin in the jar.;)
Regards, peter
I love your attention to detail Peter. I have just added 'adjustment' to my ship building vocabulary, who knows when it might come in handy. :D
Thanks, Daniel. The original Balder has been restored twice. It is almost ‘hanging together’ from the Restoration Adjustments. Then RA is quite nice next to the AL, FI and BL that we already have.ROTF
Instead of monotonously cutting 9x20 planks and sanding them, building 9x5 beams with knees, painting 240 barrels and then putting everything in place ..........
it is much more pleasant to finish it per barrel hold:
In this 2nd hold, 4 rows of barrels would be held in place with the beams. The 5th row comes against the kossing. The next hold gets 5 beams.
I have placed 2 rows of barrels in this hold. I build this up per hold with one row of barrels. The 5th hold is then filled with 5 rows. It slopes down again to the 9th hold. Then it becomes a more attractive appearance in my opinion, with more view of the wood of the holds.
Looking great Peter :) Okay
Perhaps the question then arises: "How many barrels did the ship have on board?
A brief summary of the logbook of the first voyage of the Balder that is written in the Amsterdam Restoration Book:
"The voyage lasted from 1 June to 27 July. After 5 days of sailing, the fishing grounds were reached. On 5 June, at 18:00, the first 'vleet' was set out and the next day at 01:00, the hauling could begin. At 03:00, the vleet was in. The result was small: 1 'basket'.
On Friday 7 June, 9 'kantjes' of herring were caught. A 'kantje' is a haring barrel.
The voyage lasted 57 days and the 'vleet' was set out 37 times. There was no fishing on Sunday. The largest catch was 62.5 'kantje'. The result of the entire voyage of 385 'kantjes'. So 385 barrels.
In 1914 it had once caught 486 'kantjes'/barrels on 1 voyage.
In a hold 2x25 barrels could be held. Times 9 holds that is 450 barrels. In the 1st hold 2x an extra row and under the forecastle there was also room. On the deck there could also be secured. All in all the ship had more than 500 barrels on board.
Beautiful work Peter! The wood looks great, and the barrels are very nicely painted. Great details as usual! ;)
Thanks, Dean. I painted the barrels with 3 layers of Ecoline. I used a Bruch Pen, color Mahogany:
You can paint them by hand, but then your fingers are completely covered.Sick
I put them in my Proxxon lathe. One side is in the partly opened three-jaw and the other side is pressed with the closed drill head. The tape is for keeping the jaw points in position.
The Ecoline gives nice slightly darker accents in the seams of the staves. I make the hoops black with a black Permanent Marker.
Great process!
I normally hold small parts on a toothpick, or I use a two sided tape that I make by rolling painters tape and stick to a piece of wood. Then I stick the back of the part to the tape and paint them on there. Or sometimes you can paint parts on the sprue and do touch up after removing. Each part or situation requires a different approach depending on the size, shape and how you are painting it. But the main thing is that you are creative in your approach! ;)
