HMS Enterprise 1774 POF 1:48.
This will be a weird, mostly unrelated post.
I am on 2-3 other forums, all dealing with another couple of my hobbies; archery and rimfire rifles. I've been visiting those regularly for twenty years.
I've only been on the ship building forums for several months or less.
I mean the following with great respect and even admiration. The vocabulary of many of the writers on this forum is very impressive and without bluster! I find myself having to look up a few words like "febrile" by Alex as he describes his intermittent phases of excitement over his long-term build of the Enterprise.
Of course this is also the most civil and respectful forum I've ever experienced.
Kudos to the crew. :)
(Look at me, using a ship term (crew?) in a sentence! :cool:
Good evening. I have to agree with you. Not only that but the guys here are really helpful and friendships are formed across the world.
Grant, will you be tapering the knee of the head? From the contract:
The knee of the head to extend to the upper side of the upper cheek, to be 11¾ ins thick at the stem and 6 ins at the fore end
which is quite noticeable. When this is not done the figure heads look quite bowlegged. :)
Good evening Allan.Thanks for this. I have tapered, however more needs to be done to achieve the measurements indicated the contract. Thanks again - I do value your input and encouragement.
Grant, I ran into the same problem with the Oseberg. Just barely (and I do mean barely) cleaning up the laser-induced taper caused the two halves of my keel to differ in size by quite a bit. This seems to be an issue that is lost on kit producers. They "precision" cut the parts with a laser exactly to size - and yes, the bottom face is to size, but the top face of the part is smaller. Leaving it alone either causes unsightly gaps and poor glue joints, or crooked joinery. Squaring it up makes the overall part too small. :eek: CNC routed kits would be a possible solution, but at the same time, those end mill cutters are such a small diameter that as they dull, they will deflect also, creating taper as well. The advantage though, is that the deflection would generally make the part larger on the bottom face, allowing you to square the parts up to exact size.
Good evening Russ and Paul (@dockattner ).
CNC vs laser parts. My Victory was a CNC kit and I did prefer the process better than with this laser and char removal. I am being a little finicky about the char removal and squaring up as on the whole everything is coming together pretty cool. It Looks exaggerated in the close up photos and I am leaving plenty sanding and finishing for later.
Cheers Grant
And what an absolutely gorgeous model it is! I agree with you. I would rather have my parts start over sized and adjust to the drawings. That really isn't much different than cutting all your parts on a scroll saw. Either way, you end up having to adjust them, but at least you have some meat to work with at the start - and you don't have the unsightly char marks.
True story
Good morning
I continue with the center line timbers. The fore stem and knee was secured to the keel. The false keel comprising 4 separate parts was also glue on.
View attachment 504482View attachment 504480View attachment 504481
I did experience a few challenges which still need some work. When removing the chaff despite “being very careful “ I obviously changed the shape of the cuts to create some small gaps and a tiny deviation at the false keel join -These are so minimal, I doubt it will cause a problem later but we will find outROTF.
Cheers Grant
i ask myself how much of the char needs to be removed? If there is a little left and I haven't distorted the part with oversanding then I would want to stop there, wouldn't I?
Good evening Jack. That is a question I ask myself all the time. My theory is “just enough so the char does not spoil the look of the model. “ I may have been too conservative in my removal as I would prefer a little char left than an out of shape part. Yep I agree with you. Cheers Grant
Good morning.
It was with great enthusiasm that I woke this morning to build my jig.
Alas this rapidly dissipated when I discovered I had two sheet 18 and no sheet 17.
Eish so goes it….. I will now have to wait and in the meantime construct a gaggle of frames, cant frames etc. Perhaps when I get bored I will tie some more ropes on the Bounty. :D
Cheers Grant
Good morning.
Cheers Grant
Auch...!
Good morning.
Cheers Grant
Oh crap. What an inconvenience. Hopefully you don't have to wait too long to get the one you are missing.
Let’s hope they send the right one out pronto.
Ugh. I guess it really shouldn't surprise us with all the parts in these kits. But how frustrating!
Hello Gentlemen. I have heard that Tom from CAF is pretty good with this. I sent him a mail this morning so I’m sure we will be sorted soon. Cheers Grant
Good morning.
Cheers Grant
Hi Grant
Your build is looking great. The comments on CNC vs laser are interesting. Laser cut parts have char and the "angle" problem, but CNC cuts can also be a pain in the a..... especially when the cut is not deep enough. Rooting out the CNC debris from the cut is time-consuming, the attachment joints can be thick and always need sanding, plus there is the corner problem, where all the corners are rounded, and you have to cut out the round to make it sharp-....It's all part of the fun......
CAFs Customer Service is very responsive and fast. In my kit, I had a missing sheet, plus I destroyed some stern pieces - Tom quickly sent me replacements at no cost ! I suggest that you do a complete inventory of your kit's parts early in case any more are missing.
I'm glad you followed Allan's suggestion- I wish I had tapered the knee of the head early in my build. It is a lot harder to do later.
You might want to shape and dry-fit the Lion figurehead on the knee at this time also......
Cheers
Alex R
Yuck, wrong flats, missing pieces, etc. That resurrects some bad memories. I hope your parts get replaced quickly.
Jan
Hi Jan. That it is …yuck !!! I’ve been lucky so far with this being the first missing pieces of the 3 kits….it had to happen sometime. Let’s hope replacement isn’t too far away. Cheers Grant
Your build log is starting to resemble Paul’s @dockattner - take your eye of it for a short while and suddenly there’s five pages or more. Looks great Grant but the duplicate sheet is a bummer. Mind you, looking on the bright side, we get time to keep up with your build logs while you wait ROTF.
Good morning Roger. It is a total bummer. I think any comparison to Paul (@dockattner )when it comes to model making is a humbling experience even if it is only referring to the length/activity of our log……so thanks ….I thinkROTF.I have plenty to do building a multitude of frames whilE I wait. Thanks for checking in Roger.
Cheers Grant
