Using strings allows you to pull the frames in different directions, which in my case was needed for the frames at the corners of the boards. The strings give also a more stiff connection ones they are glued to the board.So what’s the difference between stringing them and rubber banding. Explain please ?
Hi Alan, thank you for this information. There will be no second layer. For this product, Occre does not aim to have an accurate model, but just something that looks likes. I will make some changes to the guidelines of the kit, but this will for sure not be an improvement of accuracy.Is there to be a second layer of planking? The reason I ask is that the line of the gunports follow the sheer of the decks which is not the same as the sheer of the hull planking, including the wales. It does not matter for the first layer but will look odd if on the second layer, especially the wales.
Boyne 1790 You can see the sheer line of the wales which is the same as the adjacent planking. It is different than the line of the gun ports.
Glory 1788. You can see difference of the sheer of the wales/planking compared to the deck beams and deck planking. There is a high resolution version of this plan on the Wiki Commons site, page 1. https://commons.wikimedia.org/wiki/Category:Ship_plans_of_the_Royal_Museums_Greenwich If you download it the details are very clear.
I agree with you Crypton and it is a shame. The materials would have the same costs in this example so it must be something else. Perhaps it is to help keep costs down for the end product. To get accuracy takes research and doing research takes time and a person's time carries a cost. I have emailed with Xavier at OcCre in the past and he has kindly responded that he is not in charge of the technical department but passed on my notes to the technical department. They have never responded. Time to give it another try on this mistake.Occre does not aim to have an accurate model
