Alex, I'm watching your build up here in Conroe and enjoying your dialog with Jeff, Allan and Russ. Have fun, Magic Mike
So far, the joinery with the graphite-laced yellow glue is strong, but the color is more grey than black, and I don't want to add more graphite to it; I will try the art paper sometime later on this kit. I see you have a T-track table...and you are using it. Do you like it ? so far, I love mine-very practical. Is your kit the CAF Enterprize? mine is the Dockyards' 1:48..Enterprize. Your stem is of a different construction, but similar shape, to mine. Nice joinery.FWIW, I have always "suspected" the graphite powder may weaken the yellow titebond from test pieces I ran tests on. My end result is using a very porous black art paper between joints. when glued, it is quite thin, and yields a strong joint, IMHO, quite realistic. The big plus..... when hit with glue, both surfaces, just enough to fill any tiny void giving nice finish. When dry, very easy to simply chisel away from wood.View attachment 511662View attachment 511664
That said, for this project, I have finished keel, bow, transom using nothing and joinery seems realistic here as well/ all pieces here where cut scratch from stock.
That said, I have been a lurker here for some time.....great forum and looking forward to following everyones progress on this fine kit.
Tim
Thanks Mike,Alex, I'm watching your build up here in Conroe and enjoying your dialog with Jeff, Allan and Russ. Have fun, Magic Mike
Welcome Peter. It is turning out to be a great group. Glad u are doing us.Hi Alex. Found the new Group Build and your build-log. Set my chair and follow it with great interest.
Sorry for the confusion, the T-track images are of my scratch Euryalus, only to show the paper joinery. If you have an art supply, this paper is a very loose, porous weave, you can literally pull it apart , but it compresses and gives nice result.So far, the joinery with the graphite-laced yellow glue is strong, but the color is more grey than black, and I don't want to add more graphite to it; I will try the art paper sometime later on this kit. I see you have a T-track table...and you are using it. Do you like it ? so far, I love mine-very practical. Is your kit the CAF Enterprize? mine is the Dockyards' 1:48..Enterprize. Your stem is of a different construction, but similar shape, to mine. Nice joinery.
AR
Well, since you are also building Dockyards' 1:48 Enterprize, you should start your build page in this area, and show us pictures of your work. Join us, we'll be saving a dry dock in the shipyard for you. All you have to do is go to the SOS group builds and projects area and start your build thread.Sorry for the confusion, the T-track images are of my scratch Euryalus, only to show the paper joinery. If you have an art supply, this paper is a very loose, porous weave, you can literally pull it apart , but it compresses and gives nice result.
Mine is Dockyards and will go only with their jig resting on a thick melamine work surface. Have built a few frames, as of yet not glued to keel and it works quite well alone.
The Euryalus is framed out but in all boxwood the sanding was exhausting and I put it up for now under plastic. Framed and planked a scratch Confederacy, also on hold, but I hope to push through to finish on the 1/48 Enterprize
.Sorry you feel like a lost lamb. You are welcome to hang out here.Good morning Alex. Wow this looks like a cool kit. All you guys on this group are like pioneers with this MD kit. Going to be super fun with plenty sharing of ideas and suggestions. You are off to a great start. Cheers Grant
PS : I feel like the lonely lamb lost in the wilderness with my CAF version….![]()
You are quite right. Graphite has a laminar flake structure at heart, and the laminations on the graphite will fail before the glue. Carbon Black, or black powder paint would be a better choice.FWIW, I have always "suspected" the graphite powder may weaken the yellow titebond from test pieces I ran tests on.
Agree JeffLooking good !! If you look at the partss E1-11 & E1-12, as well as E2-26 and E2-27, there is a laser burn line on the inside edge. That is where the rabbet goes. It also follows along the keel as well.Personally, I think it would be easier to cut the rabbet prior to gluing. That is how I plan to tackle it.
Not a huge deal, but once I sanded the sternpost to proper dimension….with same gap, I carefully widened the gap to fit stern snugly and the entire keel assembly snapped down snugly with no bind and it fit tight against vertical support.The keel structure is now in the building jig !
A few comments for the build group:
If you haven't built the jig-
1)keep the parts so that the layered number is towards the bow...Thyer external surfaces of parts B6 and A6 should be smooth, no parts should protrude.
2)in step # 3 -platform, parts A 12 and B 12 go at the top. The build drawings show part A 11 in at the top, bow side. The part number is wrong. The part is A 12. (B 12 plus A 12 are the parts that make up the top of the side bands.)
3) The bow keel structure fits well in the front, but there is a 9/64 " gap between the sternpost and the stern support on the jig. I don't think I missed a piece, but I'll check. If anybody knows (Victor) or is at this stage (Corsair) ? Help..
View attachment 513253View attachment 513254View attachment 513255
Full keel in jig. 9/64" gap between sternpost and jig stern support. (why?) Bow deadwood fits well
Thanks
Alex R
Do you sleep ? Do you have children laboring on your ship 24-7 _. You are moving FAST....___Congratulations..Not a huge deal, but once I sanded the sternpost to proper dimension….with same gap, I carefully widened the gap to fit stern snugly and the entire keel assembly snapped down snugly with no bind and it fit tight against vertical support.
I am now through 11 frames, all only dry fit. They seem to fit, space very well and I carefully bevel with spindle sander barely off interior/exterior surfaces to allow for finish sanding. You need care with proper support pieces glued to top between frame pairs to ensure snug, proper fit in jig.
Doing this gets you about 90%.
I have sanded, test fit top/bottom gunport pieces just dry fit but since they are thinner than frame tops, trying to figure when I do fit them to align them to the outside frame surface, or inside, or middle and then sand frames to match.
Victor……any advise?
Worth a mention/ question, with your solution keeping the post somewhat away from the jig, will it, perhaps, throw the geometry off slightly when setting up the upper structure? This is what I scratched my head about and ultimately decided to insure the post was tight against jig.Thanks Doc...
I jlooked at the build carefully and I did not miss a piece or made a mistake ( not know what I don't know) just sanded down a piece of spare wood to fill the space between the jig stern support and the sternpost. I don't like gaps, and this piece will just add support
to the keel. The second picture shows the sternpost and the new support piece from above. The sternpost is tapered and sanded down to 3mm.
View attachment 513266View attachment 513267
Cheers
ALEX R
