- Dec 3, 2022
I started the bulwark planking tonight mostly to 'allow' myself to post an update and reply to all of those helpful suggestions. I hate having unanswered documents in my mental in-tray.
However, the first planks above deck level went on fine. I've already glued the next four and I'll affix them another day, just to see if the glue will still work when totally dried. The bulwarks will be three ply when I've finished; there's going to be an inner layer of nice wood as well as an outer one. I have plans to make both blingishly interesting.
I can't do more tonight because I ate a HUGE meal this evening and my stomach is hurting. Must. Lie. Down. If I carry on like this I'll have big hips too!
But first ...write replies.
Gotta be careful working those bulges off because you can lose muscle in the process.![]()
Good advice Bo, if I sand the bulges any more I'll go right through the skin and be carving away flesh and bone, leaving a gaping, gangrenous abscess requiring major surgery. Definitely not the way to enjoy myself in the hobby.
Since there is another layer of planking yet to come, it’s nothing
You are right Nama, it's nothing. It's a fictional ship. There is no standard to work to except my imagination.
a generous coat of body filler won’t fix.
Right again. Body filler won't fix it. The boat has thick hips and the only thing filler can do is make the waist even fatter than the hips. That's not a step in the right direction.
I noticed when I started to plank so managed to overcome the problem with some shimming etc.
I kinda noticed when I was fairing but didn't file down the offending frame enough. I'm now doubting that I transposed the frames as they increase and decrease nicely measured across the beam - I think it's just that bulkhead with the angular corner that I mentioned earlier. It doesn't really matter what the original problem was, the point that you make so well is that I didn't notice in time to make easy adjustments. Mea Culpa.
We all make mistakes and the wise learn to live with the consequences?
I am sure you can hide it a bit.
I have a much better idea than hiding it. I'm going to...
...leave you wondering until later in the build.
Hi Smithy. Yikes.
Not even "Yikes".
It's fictional yeah? (Not one of your 'true stories'
Detach the planking on the frames with the arrows and put an adequate thickness, this is what I would do. Frank
"Striving to better, oft we mar what's well" Shakespeare, King Lear. With another theatrical reference I refute the need to start over.
Think of it as a cost/benefit analysis.
The cost of tearing the planks off and starting again would be a week or two of time, which is nothing really. But, knowing myself well, I can say with certainty that my interest in this project would be terminally wounded by a re-do. The same would happen if I went the body filler route. I'd finish by throwing it away and starting something else. True story!
The benefits of 'fixing' this 'problem' would be minimal. Because I don't care if my hull is imperfect. I'm very pleased not to be cursed with perfectionism in any way. Child bearing hips have never caused me to reject a saucy smile, so I'm not going to start now.
Oh well, I’ll just have to live with it now.
I knew I'd at least implied that it was no big deal to me.
In fact, if you stick around for a few more pages to see how I'm not going to hide it, you'll see that the lumpy hull is a story-telling opportunity rather than a catastrophe.
