- Mar 13, 2025
This past weekend began the cross-section. The Admiral bought it for me and would like to display it in the Dining Room. Spent time thinking about what I wanted to do after looking through other build logs. Have decided to veneer the outside frame pieces to give them a more realistic look. After putting the frames together, I have begun working on making template pieces for the veneer.
At first I was using some basswood to make the templates. Then found it much easier to use some card stock. Would like to get them as close as possible before cutting the veneer pieces.
So far I have gotten templates done for the bottom four pieces. Hope to continue the remaining pieces tonight. Purchased a veneer variety pack that should be delivered today. I am excited to look through them and pick out which ones to use for this build. The veneer pieces are 1/42 inch thick so I purchased some pinstripe tape, 1/64 inch to use between pieces as the caulking. Hoping over the next couple of days to have the frame veneer pieces cut and ready to assemble.
