Here is a link to a spindle sander. I have one that has a horizontal belt attachment as well.What is a spindle sander please
Link to Spindle Sander
So, are you going to create a build log and join us here in the group build?Really helpful Just ordered the Kit (WEll Monday)
Was a bit worried as I messedup Blandford with Stain Will follow you exactly and get it right
Had too buy my wife a new Cooker to justify this purchase
O Well when i had a ne quattro it was a diamond ring Q!
Not all the same. There are 37 frames and another 16 cant frames. The frame numbers from 1 to about 12 provide a taper to the hull so they are a different shape with different tapers. Then again starting at about 24 through 37 also has a different shape because you are getting more of the V at the bottom near the stern as you get closer to the rudder.Why not just Copy it Should be 100% and no need to use cling film
thank you - The rest would be good but ive got a Belt Sander which hopefully will be OKHere is a link to a spindle sander. I have one that has a horizontal belt attachment as well.
Its going to be really tough to sand the inside of the frames with only a belt sander.thank you - The rest would be good but ive got a Belt Sander which hopefully will be OK
No. It's not painted at all. That's just the colour of the wood. Probably the light making it look whiteI assume its painted white so you can see what stuff you have taken off ?
Really quite confident about the build now THANKS
I use a hand held spindle sander for fairing inside and out. Wouldn't use anything elsethank you - The rest would be good but ive got a Belt Sander which hopefully will be OK
Yes I think SoSo, are you going to create a build log and join us here in the group build?![]()
Create your own, new build log in this section specifically for builders of this kit.Yes I think So
Be interesting Not done it before
Paid For And hoping it will be here Maybe Next week
When you say group build are you saying i can add comments on here
Or Create a New Build LOg
You can buy it hereHello Keef,
I'm seeing your build report for the first time now. What a wonderful kit you've bought. May I ask where you purchased it? It's definitely something for me once I finish my Victory in a few years. After all, one should have something to look forward to.
I’ll continue to follow your adventure with great interest.
Best of luck!
HiYou can buy it here
https://drydockmodelsandparts.com/p...rest. Best of luck! [/QUOTE] 48-pof-pearwood
You can buy it here
Hms Enterprize 1774 1:48 POF Pearwood + Boxwood Decorations
Shipping is included in the total price!! Please allow 14 - 21 days to fulfill and ship the order!! The product is shipped from China!! The Enterprize class was designed by John Williams, the successor of the renowned British ship designer (surveyor) Tomas Slade, in 1770. He made minor...drydockmodelsandparts.com
Hi. Thank you very much for your interest in my build log. Yes This is a great kit and a really interesting model to build, as is your Victory. Good luck with that btw. Drydock Models & Parts have beaten me to it, but this is the company to contact with your order. It will be good to have you alongHello Keef,
Best of luck!
Hello Keef,
Best of luck!
Sorry what i mean is Photocopy it ie EACH Plan Mens you dont damage the original or need cling filmNot all the same. There are 37 frames and another 16 cant frames. The frame numbers from 1 to about 12 provide a taper to the hull so they are a different shape with different tapers. Then again starting at about 24 through 37 also has a different shape because you are getting more of the V at the bottom near the stern as you get closer to the rudder.
I hope that helps.![]()
On each drawing, just stick a small strip of tape over each place where there is a joint, chock or scarf joint. The glue will not stick to the drawing and you can reuse the same drawing for both A and B sides without the need to copy the originalsSorry what i mean is Photocopy it ie EACH Plan Mens you dont damage the original or need cling film
Although i presume cling film stops the glue/frame stickeng to the Plan
Like the idea of a hand help Spindle sander can you post a photosI use a hand held spindle sander for fairing inside and out. Wouldn't use anything else
This is the tool I have found to be the best for sanding and fairing the frames. Use 120 grit sanding tubes as they are not too course and use very gentle pressure as you sand in one direction only (against the direction of rotation of the drum). Make sure to have plenty of spare sanding tubes as they wear down pretty quick. Maybe about 4 to 5 frames, inside and out, per tubeLike the idea of a hand help Spindle sander can you post a photos
Just been advised that my Enterprise will be shipped on Tuesday should be with me the following week
Cant WAit Is this what you mean
