Anchors - Model Ship Fittings - Modelers Central
Model Ship Anchors Come in a Range of Sizes and Shapes. Modelers Central Is The Home Of Wooden Model Ship Builders. Order Online For Fast Delivery.www.modelerscentral.com
I'm sure there are others as well if you don't want to make your own...
Hey Paul,![]()
Good morning Gunther. I totally agree the little ships boat is looking much better. Lovely work. Cheers GrantHey friends,
another little update from me. I had to make a few changes that I didn't like. Working at this scale is really getting me down. But, it should look nicer than the horrible dinghy of the Black Swan. But what did I do?
I replaced the gratings with maple gratings. These had to be cut to shape, sanded and then rounded off with a 0.3 mm maple strip. Then I turned my attention to the dowels. After all, my rudder straps have to be held and used. To do this, I sanded a lime strip to 2 x 0.5 mm. Then I clamped it in the vice and inserted a curved shaft with the cylindrical sander. Then I took 0.5 mm needles and shortened them to 2 mm. These are supposed to be the real dowels. The wood serves to stabilize the dowels. I glued both together with a lot of effort and holding my breath. It took sooooo long, as many of the cannulas simply slipped away and were lost forever in the nirvana of the carpet table.
As always, here are my pictures.
Best regards
Günther
Oh yes, this is what the little dinghy looks like now. It's not finished yet..... but I think it's already better than that awful dinghy...don't you?
Good morning Grant,Good morning Gunther. I totally agree the little ships boat is looking much better. Lovely work. Cheers Grant
Hey Namabiiru,That’s amazing! Do you solder the crest to the barrel, or use CA?
Hi Namabiiru,I’m not familiar with that kind of adhesive. I would like to learn more. For some thing like that, maybe solder paste would work. I use that very effectively for small parts.
Hey Namabiiru,I’m not familiar with that kind of adhesive. I would like to learn more. For some thing like that, maybe solder paste would work. I use that very effectively for small parts.
Hey Namabiiru,
look here. This ist the glue!
Superglue metal extra strong 30g - Metal glue waterproof, heat-resistant & with needle lock to prevent drying out - Metal glue for bonding...
It is really bombproof and so it always saves me soldering. Especially with small parts. Like with my mini coat of arms.
Cheers
Günther![]()
Hey Jim,Hi Namabiiru,
Some time ago, I made a review of aftermarket naval guns where I used to soldered the crest to a barrel using soft silver solder. Specifically, section: Working with gun barrels.
Parts review - Aftermarket naval guns parts to upscale, Part 2/3
Greetings all. This is way long past-due log of Part 2 of 3 series: Accesories\Uspscale mini kits of naval guns. To those of you who came directly to this post, please follow the below link to get familiar with our discussion about aftermarket naval gun mini kits...shipsofscale.com
Please let me know if you have questions.
Good job. One piece of advice for the future. Take all the wood you will use and cover it with different types of oil (if you will apply it) and let it lie where the model will stand in the future during the entire construction period. This is necessary in order to see how much and how the color will change. Because the result immediately and after a couple of months varies greatly and, for example, light wood species can turn very yellow from some types of oils, and the samples will show you this so that there are no surprises on the model later.
