Daniel,
Wow - just repeating other posts here. Beautiful work indeed. Have been following - now catching up!
Hello John, thanks for looking in, I hope you enjoy the show.Daniel,
Good afternoon Johan. Maybe a Kolibri -N3 could park itself on my helipad.…Looking great, Dan, your patience and perseverance paid off quite handsomely.
Seeing that transom made me remember a certain South African, who was also building a Xebec and considered implementing a helideck on the transom. Unfortunately this idea never bore fruit. Maybe something for you to add on as a nice customization to your Xebec and possibly even adding a Sikorsky Sea Dragon on mentioned deck?
Nice try, mate: wrong scaleGood afternoon Johan. Maybe a Kolibri -N3 could park itself on my helipad.….
I know how that goes!Thanks Dean. I haven't done much with the ship in last couple of weeks, I've been remodeling our backyard storage shed (new roof and siding with trim) that I built over 25 years ago as well as some other home improvements. We are always building something it seems.
Nice! We all have side projects.Hello all, as follow up my post #226 I have one finished build I am excited show off a little. The facelift is now complete on my potting / storage shed. View attachment 526285View attachment 526286
Ok I promise my next post will be back on the Zebec’s build. Thanks for indulging me.
Till next time!
Very cool Daniel. I would ask you to make me one but it would fit in my gardenHello all, as follow up my post #226 I have one finished build I am excited show off a little. The facelift is now complete on my potting / storage shed. View attachment 526285View attachment 526286
Till next time!
Is it just me, but doesn't the skeleton look terribly fragile?Finally, back to my very fine Zebec. For better access, I removed from the jig its thinner crossing elements which completely opens up the interior. Next I set the three pieces making up the keelson, I had previously spent several hours filing the char off each rib location and test fitting lots of times so all 90 ribs fit in comfortably.
While I still have a lot to do on the transom, I instead began setting the clamp strakes on the aft upper deck section which when completed will allow me accurately to set some intermediate ribs which will have to rely on the clamp strake for their proper alignment. These five short ribs on each side fill in this area solid which gets a port hole of sorts cut into it. Now what's interesting is you cannot set these four little ribs with the upper level of the jig in place; it must be removed so I figured better go with the clamp strakes now. Here is what I am talking about, by the way they do not mention this build sequence anywhere.
The clamp strakes as well as all the internal strakes are 1x5mm pear, which is fairly stout, so I soaked and pre bent them for installation. I used my favorite bending helper a curling iron, it gets very hot and works like a champ.
View attachment 527560View attachment 527562
Thats all for now, till next time thanks for dropping by.
Indeed, it does look fragile Johan. The ribs especially the uppers are twice as small as were the Blue Nose ribs, they are quite stout though, all made from pear. I've plucked a few moving in and around them but have not broken any yet.Is it just me, but doesn't the skeleton look terribly fragile?
Congrats on a BIG milestone, Daniel! Potting shed???? I expected you to say it was your new "sanding station", after finishing your hull framing.Hello all, as follow up my post #226 I have one finished build I am excited show off a little. The facelift is now complete on my potting / storage shed. View attachment 526285View attachment 526286
Till next time!
Thanks Ken. The potting part is for the admirals gardening; the shed part holds my lawn equipment and me if the admiral ever deems it necessary!Congrats on a BIG milestone, Daniel! Potting shed???? I expected you to say it was your new "sanding station", after finishing your hull framing.![]()
A impressive sight, Daniel. The amount of frames as well as their dimensions.Finally, back to my very fine Zebec. For better access, I removed from the jig its thinner crossing elements which completely opens up the interior. Next I set the three pieces making up the keelson, I had previously spent several hours filing the char off each rib location and test fitting lots of times so all 90 ribs fit in comfortably.
Thanks Peter, I fully anticipate the frames become quite stable once the rest of the internal stringers are in place.A impressive sight, Daniel. The amount of frames as well as their dimensions.
