Impressive effort, Herman!
**VIEW THREAD HERE** |
The appearance of the sanded nails is very very nice and subtle, Herman.Still nailing.
Extra nails were inserted, as @Maarten suggested, where the part of the frames overlap each other and form an almost closed wooden wall.
Below the wales the nailing is completed and that part was sanded again.
On the port side the holes for the wooden nails were drilled and all wooden nails are now inserted there. I have enclosed pictures where you can see the new forest of nails and the result of the nailing below the wales.
Herman, very nice work! Do you trim those with flush-cutters or a saw before sanding?The appearance of the sanded nails is very very nice and subtle, Herman.
Witaj
Bardzo żmudna praca z kołkowaniem ale piękny efekt Hermanie ,podziwiam . Pozdrawiam Mirek
My running count totaled over 13000 treenails on the Kingfisher (inside and out - but only one side had planking) so I feel your pain!Thank you Paul.
And after this side is finished there is still one side left to do above the wales.
Yeah it takes some perseverance. I estimate I made about 10000 nails originally and am now almost out of stock. In the process of nailing I could re-use a considerable amount of what was left over from cut nails. So I lost counting.My running count totaled over 13000 treenails on the Kingfisher (inside and out - but only one side had planking) so I feel your pain!
A very beautiful hedgehog. The amount of work you put in is totally justified by the end result. I still don't know how you counted the nails, but I believe you. I only had the perseverance to pound the nails, counting them is out of optionStill nailing.
A very good question, let me explain why. I used flush cutters, but did my best not to cut the nails flush with the hull because that might damage the nails at the heigth of the hull. I leave them somewhat protruding
As it is my first model...
Love the chaos.Still nailing.
It is a bit of an organised chaos as only extra nails were added between my originally planed pattern of nails. But I am grateful for your suggestion. It looks so much better.Love the chaos.
Ditto.The appearance of the sanded nails is very very nice and subtle, Herman.
Thank you my dear friend. One time consuming job.excellent planking, Dear Herman
