Corsair H.M.S. Enterprize Build Log
Probably.
I'm talking about using it in stages AFTER construction is done, kind of from the keel up, frames/one deck at a time, when I get there.
That said, what are you're thoughts as to final finish options ?
Was also considering bees wax but ,a.sounds like it has dust issues and, b. seems a lot of wipe on poly use out there so I'm open to thoughts.
If I may interject here, I would definitely test that process on some scrap that has been prepared exactly like your frames. Having worked with a lot of different finishes, I can't think of any that won't show a line where you stopped and started again. Perhaps if you did that just on the inside faces of the frames that would be inaccessible later, the deck structure would hide the demarcation, but I don't think I would do it that way on any surface of the frames that will be visible.
The process I will probably use has, from what I've seen has been used on a large number of high end scratch builds with zero issues like that that I am aware of. I guess one of the benefits of the poly.
Being able to treat areas that will become inaccessible and likely ending up with more than a single coat seem to blend everything well ion any test pieces I've tried given a single coat is fairly subtle.
Even spot repairs seem doable with varying applications and required feathering.
All this said, make no mistake, my primary effort will be largely on interior decks/structures that will be hidden and not painted, frames, planking, will likely all be done in one shot.....number of coats to be determined.
Russ, given your comment in regard to finishes, do you have a suggestion ?
Ok, just remember, you asked! ROTF
The two major categories of finishes are film and penetrating (oil) type finishes. Each has their benefits and drawbacks.
Film finishes, as their name indicates, leave behind a film of solids on top of the surface. These include shellac, varnish and polyurethanes (both solvent and water based) in order of the amount of protection they offer. Shellac is the easiest to use, but offers the least protection, especially to water and alcohol. Multiple coats do not require sanding (other than to remove dust nibs), because each successive coat partially dissolves the previous one and forms a chemical bond to it. Varnishes and polys require scuffing between coats because successive coats need a "tooth" to form a mechanical bond to. Marine varnishes and some polys offer UV protection which will help slow down (nothing can prevent) the darkening of the wood from exposure to UV light (even from a window).
Oil finishes include tung, linseed and others. Most name brands like Watco are really just boiled linseed. Boiled? Most oil finishes take a very long time to cure unless they have driers added to them. Tung and raw linseed will take days to weeks to cure. Boiled linseed is not really boiled, it just has those driers added to speed up cure time. The advantages of oil finishes are that they are easy to apply, don't require sanding between coats and they really bring out the figure of the wood and add a lot of warmth to it. The downside is that they offer very little protection at all. This is not really that important for a ship model that probably won't be handled that much or exposed to the elements, but the wood will darken quicker with exposure to UV.
My personal opinion is that film finishes make a model ship look "plastic-y". Oil finishes really enhance the beauty of the wood, but offer no protection and the best of them all - tung - takes forever to cure. Hmmm, what to do?
In the early 2000's, I briefly tried making a living as a professional woodturner along with teaching the craft to others. Unfortunately, if you recall, that was right when the US economy started tanking and we were entering a recession. People just stopped spending their discretionary income on artistic things, so I had to go back and get a "real job". ROTF I did, however, have the opportunity to try a lot of different finishes on my work and settled on one that quickly became my favorite. Unfortunately, you can't buy it in any store. :( You have to make it.
It's called "Old Timer's Finish" and you make it by blending equal parts of high gloss marine varnish (not poly), pure tung oil (available at WoodCraft or other woodworking supply stores), and solvent (you can use mineral spirits, but I prefer turpentine 'cause I like the smell.) I know, weird! I mix it in small batches because it will tend to gel after 2 or 3 weeks. About two fl. ounces (60 ml) of each. The amount is not critical, as long as it is equal. I use 6 oz. poly squeeze bottles from Michaels (in the cake decorating dept.) to mix it. I just draw three lines around the circumference with a marker to give me 3 equal portions and just add ingredients to the lines, then shake. It's easy to squeeze out onto a cloth and when you're done, squeeze all the air out before putting the cap on and it till last much longer. It's the oxygen that makes it gel. Do the same with the tung oil bottle, and transfer it to a smaller bottle when you can no longer squeeze all the air out.
Anyway, It works because all the ingredients are compatible with one another and you apply it as you would a wipe-on varnish or poly - with a cloth. Here's how it works: The tung oil really brings out the figure and beauty of the wood. The marine varnish offers UV and touch protection, and has the driers that the tung oil needs to cure. The turpentine thins it enough to allow it to penetrate deeply. Two light coats will give you a beautiful, hand-rubbed look to the wood. Three or more, and you will start to get more of a film build-up, but I think that would detract from the model and make it look like plastic.
Prepare your wood by sanding thoroughly with the grain, progressing through the grits. Don't skip from 120 to 400 - trust me, it won't work. I would probably stop at 600 or 800. That means start at 120 (or if your wood is already pretty smooth, 180), then progress up the grits - 180, 240, 320, 400, 600, 800. The first grit is final shaping and removal of tool marks. All successive grits are simply removing the scratches from previous grits. The finish (any finish) will make sanding scratches pop like a sore thumb, especially if sanded across the grain even once. Also, don't use a piece of 120 grit until it dulls and then call it 320. That doesn't work, it's dull - throw it away. A highly respected mentor of mine once told me, "Use sandpaper as if someone else were paying for it." When it's dull, it will stop cutting and only burnish the surface, locking in the existing scratches and making it harder for successive grits to do their job. It's a kind of "work hardening."
Finally, whatever you do, please stay away from water-based poly finishes. I know, they're easy to get, easy to clean up and have little odor. BUT, they don't bring out the beauty of the wood like oil and just make it look dull and lifeless.
That's my story and I'm sticking to it. Stepping down from my soapbox now. :D
It's called "Old Timer's Finish" and you make it by blending equal parts of high gloss marine varnish (not poly), pure tung oil (available at WoodCraft or other woodworking supply stores), and solvent (you can use mineral spirits, but I prefer turpentine 'cause I like the smell.) I know, weird! I mix it in small batches because it will tend to gel after 2 or 3 weeks. About two fl. ounces (60 ml) of each. The amount is not critical, as long as it is equal. I use 6 oz. poly squeeze bottles from Michaels (in the cake decorating dept.) to mix it. I just draw two lines around the circumference with a marker to give me 3 equal portions and just add ingredients to the lines, then shake. It's easy to squeeze out onto a cloth and when you're done, squeeze all the air out before putting the cap on and it till last much longer. It's the oxygen that makes it gel. Do the same with the tung oil bottle, and transfer it to a smaller bottle when you can no longer squeeze all the air out.
Well in point of fact, I asked for a suggestion, not a tutorial.
Let’s remember, in this case it’s more about protection/ preservation, Pear, for all of it’s benefits is not really a striking material.
As examples, I include a couple pieces I enhanced/ refreshed myself using now, unavailable, Arrow wood finish, but requiring multiple rubbing/polishing sessions, largely impractical for this type of project, also have used Purdy system oil finish on fine walnut….lots of elbow grease.
Thus the proven result( from some pro admiralty builds) from what I’ve seen using the wipe on poly.
Not the best photos but I think you’d agree, some examples of very fine walnut.
Admins: if posting rifle pics here violates anything , please remove. Only post them as examples of nice wood/wood finishes.
You're welcome.
If it doesn't help you, perhaps someone else reading this will find it of use. Your gunstocks look great. I would choose the first one as closer to the type of finish I like on models, the second is too glossy for a scale model (in my opinion). It looks great on the gun, though!
I just finished up the last of the glue up for frames 18, 19 and 20. Once they are dry, I'll trim down the chocks where they are wider than the frame and then glue all the halves together for 15 through 20. Then the plan would be to get back at building frames. :)
Now up through frame 20 has the half frames assembled, the chocks are trimmed and the half frames are glued into a frame! Next is the interior and exterior sanding which I can't do until the glue connecting the half frames has set (tomorrow). I've also started assembly of frames 21, 22 and 23. I'm past the half way point on the full frames !!!!
So, here is a few more pics of the ongoing build. These parts are for both the bow and the stern.
I have also glued the pieces of the keel together but no picture of that since it just looks like a stick. ROTF
You can see pieces of the keel at the top of the middle picture, if you really want to see them.
The flat portion of the keel measures about 72 cm (or a little over 28 inches if you prefer).
I'm trying to work out in my head how to make the kerfs in the bottom of the keel and make them look good.
View attachment 512290View attachment 512291View attachment 512292View attachment 512293
I ;presume you mean Scarfs on keel Great work GThansk
All making it easier for me
Hi Corsair, you shall glue two E1-1 and two E1-2 together, then glue them onto the keel, and then install the stern. This was indeed missed on the instructions, I will add them on and update it. I will answer the questions of Alex in his post.
ModelShipyard has this been added to later instructions
Maybe the instructios should have a version Number
Well, I finally have the keel totally put together and in the construction jig. :)
Also worked on trimming down the parts of the chocks that should be. Had a glue joint break where I was cutting the chock and had to re-glue that half of the #1 frame and cleaned off the char on the second half of the #2 frame.
nice to see we all make mistakes Well spotted
The most recent version of the instructions that I have found is 1.01.
You can get them at this link:
1/48 HMS Enterprise Instructions
You will have to scroll down a little bit in the thread to get the newer version I have noted.
No, the parts in question have not been added to the current instructions. There are also some other things that should be adjusted in the instructions. The ones I found were all noted in my build log I believe.
Not even received my kit yet (Should have been today Now Tomorrow) [Luckt as i had to take my Granddaughter to her Prom in the Porsche)
This sounds amazing I presume you do it to finished rib before attaching to keel - I assume glue will stick after We call it French Polishing I think
You're welcome.
Both pretty much the same, one just suffers from lousy lighting/reflection
Hope that was as much fun for you as it was for Wayne and me. :)
So far but while the framing has been done, it was exhausting.
Taken a break….scratch Confederacy, now planked to the wales and here, which IMO, allows for a nice, fluid pace with a scratch like result without a lot of historical compromise, all, while not inexpensive, a very fair value.
