HMS Agamemnon by Caldercraft
Overijse Vlaams-Brabant
Hello everyone,
As promised I start building the Agamemnon.
I hope for interesting discussions and lots of feedback.
After opening the box I was already confronted with a big disappointment. A part of the stern basic hull being broken!!!
I contacted the shop where I ordered the kit. He in turn has to contact his supplier who in turn has to contact the company Krick in Germany. And then Caldercraft in the UK... That will take a veeeeery long time I'm afraid. I will try to contact Caldercraft (Jotika) directly for a replacement...
In the meantime I will try to glue the broken piece...
And the instruction manual in German!
My prefered shop purchased the kit in Germany..... :(
Bad beginning good ending?
ROTFROTFROTFROTFROTFROTF
In addition to the many contemporary drawings have you downloaded the original contract for a 64 of 1779 which would have had the same basic contract sent to Buckler's Hard for Agamemnon. https://www.rmg.co.uk/collections/objects/rmgc-object-388110 It is missing pages, but there is also the contract for Nassau 1785, https://www.rmg.co.uk/collections/objects/rmgc-object-459341 which is some years later, but close in overall dimensions. Nassau 160' 0" versus Ardent 160' 6" versus Agamemnon 160' 0" Should any dimensional questions arise, these two contracts should have answers.
Looking forward to your build!!
This really shouldn’t be a problem at all, no need for disappointment. You can simply glue that piece in place when attaching the designated bulkhead. It doesn’t bear any structural load; its main purpose is just to help align and support the bulkhead during assembly. However, If you’re still concerned, you can reinforce it by gluing a small square strips on either side for added stability.
Hey my friend
Thx... I'l look into it..
Marc
Good morning Marc. A very cool ship to build. I have pulled up a chair and wishing you plenty success, adventure and mostly fun with this project. Cheers Grant
Hi Marc,
I hope you don’t mind if i pull up a chair too.
Agamemnon is one of my favorite kits, but i have the Diana to build first.
When I opened my Diana I found the keel and the entire panel was missing. I contacted Jotika directly and also through my local supplier, it took 3 months to replace but they were very helpful, just many businesses and postal groups involved.
Watching with great interest.
Michael
Seems like you are having no luck! I hope it improves.
The slots for the bulkheads are such a strange shape. Are the bulkheads profiles to match the slots?
By the way, I have the exact same Proxxon vice, and have found it is not suitable for fine milling work. It does not support work pieces very well. I use it for simple holding jobs on the bench and mounted a different vice to my X-Y table.
I will start with the bulkheads next week, so I will come back to this.
Good to know the vice is not up to par. I am not there yet. Which one did you mount on the X-Y table?
There are about a thousand versions of this on the web for various prices:
It’s probably not the best thing, but inexpensive and a big improvement over the proxxon vise. I had to create a mounting plate from aluminum to attach it to the cross-slide.
I received today some new tools (which I need eg Proxxon TBM220, the KT70 and same additional devices).
But, after opening the box of the Bench drill, I saw a broken on-off switch that was dangling loose in the box..
Hmmmm, so returning the drill to the Netherlands....
It's a very common switch used on 100's of tools, available on ebay for a € or 2, saves the hassle of arranging returns.
Your delivery man is one rough guy. Ask him to put the packages on the porch, not to throw them there from his van.
It's a matter of principle for me. I paid good money for it and I expect a correct delivery. Moreover, the box was already opened and damage to the paint of the foot etc.. I suspect that the device was dropped and put back in the box....
Consider it a test of your knowledge. I purchased a kit in France. Wh3n on holiday. Didn’t think the drawings, the manual all in French. So noe I know French names for lots of the ship and it’s rigging.
Well, I did, but that was 20 years ago. An entertaining model to build though.
Jim
Gentlemen,
I would like to have your opinion on the following:
The guns on the lower deck are dummy ones. You actually need to attach the supplied guns to the plates.I am considering just closing the lower gunports.Is this a good idea?Please let me know.
Personally, I would add the guns, but it’s not my build. ;)
