H.M.S. Enterprize 1774 1:48 - Modelship Dockyard by Corsair Build Log
I'm trying to decide if it would be easier to install the cant frames first, before gluing in the full frames, or to glue the full frames first....
Any suggestions out there? :)
IMHO do not. Do all full frames and then the cants.
I did them first but ended up with lots of sanding to make them flow to the bollards.
Do the bollards/ full frames and you can adjust individual cants to get a nice sweep to the bow. Far easier to avoid unwanted jogs, etc., possible at mid frame curves depending on how the angled bottoms are trimmed to fit keel.
Keep bottom thickness as constant as you can, even if they are thick on the bottom/outside which will all be sanded down a lot to marry up to keel.
Hi Jeff, what does the instruction manual suggest? Sometimes, the steps outlined in the manual play critical roles.
It really doesn't say. They do the construction of the frames, then the construction of the cant frames then the construction of the hawse pieces. Nowhere does it specify to glue to the keel. Although you could consider gluing the components on as you build them.
Thanks TIm! I appreciate your suggestion. :)
Hi Jeff. Have you completed all the frames? I'm not sure that it matters what order you install the frames, but I personally would opt for the installing the full frames first. No reason other than the hawse pieces need to be made up using x8A and I want to do those last. Although with the full frames in position it will cut down on the available space to get your hands in. Sorry, not very helpful
LOL The lack of "available space to get your hands in" is exactly what I'm concerned about. ROTF
Oh, to answer your other question, no, I've not completed all the frames. I started with frame #1 and I'm just starting on 24, 25 and 26. So, I'm getting there. :D I also started building the hawse pieces along with making X8 frames just for something else to do while glue is drying on the frames under construction.
Not a problem.
Once the tricky bottom angles to fit keel are established( go slow)) the frames locate on the stepped keel rather well, the notches up top on the jig work rather well . Once you apply glue you can worm your fingers through the bottom of the jig to insure you have a nice, tight bond.
Not a problem.
Thanks. :)
That depends, Jeff. I'm not familiar with this particular model, but if you need to do any fairing of those cant frames, 'inside' the hull, it's usually much easier to do so 'before' the square frames are added. Those square frames closest to the cants will often get in the way and sometimes even get damaged while trying to fair the cants. I'd personally fair the cants first, then blend the square frames into the cants once the square frames are installed. Much easier and safer that way, usually! ;)
Well, I pulled a muscle in my back on Saturday and I've not done any work in the shop since. It's doing pretty good today, so I hope I can get out there and work on some frames some more. :)
Wishing you a speedy recovery!
well, I tried to get a little bit of work done while I wasn't feeling well and now I have to deal with a few messes that I created that basically involve me completely disassembling a couple of the frames I put together. :D
I guess that is what I get. LOL
It will just add a little time to building this beautiful kit
How well I know this same situation.
Work when your not feeling totally up to it, either you leave knowing you can fix it tomorrow or you come back the next day wondering who else is working on your build. Some day I will catch that other shift worker. LOL
The instructions are really bad
You can download them
I dont think i could build it without Keith and Jeff
Using Titebond means itys easy to disassemble Ive bough a special HeatGun with a Digital temp dial REALLY helps
