Would have been a very nice swimming pool. Alas...
Paul! Literally laughing out loud! Thank you, my friend!Would have been a very nice swimming pool. Alas...
Good to see that you take your time to align the parts of the base structure, Chuck. It’s looking very promising.Here's the last post for the now - all of the frames provide good contact and support for the decks EXCEPT frame 16 - the last frame. Unlike the others, frame 16 installs at an angle - so you need to add material to it's top and fair that material to match the camber of the poop deck frames 13, 14, 15. Once you've got that done you can glue the decks down and start installing filler blocks at the bow and stern before planking.
View attachment 525716View attachment 525715
Happy modeling today, shipmates! And for those of us who are also dads, I'll say an early Happy Father's Day!
Blessings. Peace. Gratitude.
Chuck
Too hot in the hot tub! LOL Jerry!Right above the boilers, it could have been a Japanese bath
Peter! Thanks for checking in! Yes, in my own small way I make an effort at precision. I am trying to make art but a Dadaist or abstract expressionist version of L'Orenoque is not what I'm going for.Good to see that you take your time to align the parts of the base structure, Chuck. It’s looking very promising.
Preach brother!This ALL sounds waaaay too familiar when building Mamoli. The plywood is horrible to fair. And if (as in my case) you use filler blocks to compensate for the dearth
of bulkheads to create a fair curve of the hull, the denseness of the plywood edges of the bulkheads sand at a much different rate than the filler blocks causing a distortion that is a nightmare to control!These (as well as the problems described in the build log above) appear to be endemic to the brand.
But they do provide a place to start if you choose to build a variety of unusual worthy subjects one may want to model that other kit makers do not provide.
However, if you want to build such worthy craft, you may be just as well off starting from scratch. At least you won't be required to compensate for the many inaccuracies and design flaws built into Mamoli kits that in some ways (IMHO) make them more demanding than scratch building.
(Meaning no disrespect to Mamoli/Duseck and Model Shipways, I can only speak from experience. I would encourage Dusek to revisit some of their products as these issues are brought to light by those of us who choose to embark on one of their kits and revise them accordingly. Clearly, the company has shown a willingness to make improvements over the original Mamoli offerings much to their benefit.)
Cases in point from personal experience, or as revealed in build logs on this forum:
'L'Orenoque"
Yachts "America", "Brittania" and "Puritan"
clipper ship" Flying Cloud"
With all due respect, Peter Gutterman
Are you sure about the scale of the gun? At 1:100 that looks very big...What ho, shipmates!
Well, here we are again. This kit![]()
. Here's the general summary. I have completed the second planking and planked the bulwarks. I started planking the deck. I have figured out the actual armament which were six Paixhans No. 1 shell guns - a/k/a Canon-obusier of 80. I have also determined that the Paixhans gun is almost identical to the US Navy's pre Civil War Gun no 1.
View attachment 530393View attachment 530392
And then . . .
And then I took one of my spare IX inch @JerryTodd Dahlgren's on a Marsilly carriage and put it on the deck. I learned that top of the bulwarks just reaches the bottom of the Dahlgren's barrel. So, even though the Dahlgren (about 12 feet long) is somewhat larger than the Paixhans (about10 feet long) it is clear to me that, YET AGAIN, the bulwarks need to be raised.
For your reference, the Paixhans guns will be about 1.25 inches long in scale compared with the IX inch Dahlgren which is 1.5 inches long. The good news on this kit, as opposed to Harriet Lane, is that I discovered the problem before I had effectively finished the hull. The bad news is that by raising the bulwark height by 12 - 18 inches - 1/8 - 3/16 scale inches, I may throw off the broadside profile of the hull which is about the only thing the designer got right.
Picks of the guns aboard. The Dahlgren next to the object supplied in the kit. BTW the kit gun is a complete piece of garbage IMHO.
View attachment 530397View attachment 530396View attachment 530395View attachment 530394
If anyone decides to build this kit you'll want to lower the main deck by 3/16 - 1/4 inches (about 18 - 24 scale inches) to make sure that your guns (relatively accurate - not garbage kit guns) sit properly in their ports. I think the problem for the designer was the lack of information about the actual height of the bulwarks. I haven't found anything giving this information. On the other hand, how could it be that the real ship only had 3 feet tall bulwarks? Someone loses their balance in a choppy sea and is overboard - end of story. Moreover, given the ships actual armament and broadside profile plans, the deck had to be low enough for the guns to sit squarely within their ports. So, with that, shipmates, I am off to the shipyard to make L'Orenoque 12 - 18 inches taller. See you on the other side!
Chuck
Paul! I'm confident about the scale of the gun. The Dahlgren and the Paixhans are similar in size. I was using it to get an idea of what the real guns would look like on deck as opposed to the kit gun. Even a slightly smaller gun will require higher bulwarks.Are you sure about the scale of the gun? At 1:100 that looks very big...
In that case you have a big problemPaul! I'm confident about the scale of the gun. The Dahlgren and the Paixhans are similar in size. I was using it to get an idea of what the real guns would look like on deck as opposed to the kit gun. Even a slightly smaller gun will require higher bulwarks.
I will confess that I re-scale things in my mind - equating 1:100 to 1:96. So the Dahlgren is very slightly larger in scale. Given the Paixhans similarity to the USN 8 inch shell gun, I went back to @JerryTodd Jerry's Constellation log. Here's a pic I copied from Jerry's log so you can see the relative sizes. Keep in mind that these are 1/36 scale. I think the low bulwarks and the kit supplied pop-gun add to the impression of the Dahlgren's being wildly out of scale.
Blessings.
Chuck
Pete! Thank you! I am almost finished with the heightening process and plan to post a lot starting later this evening. The height of the bulwarks makes a huge difference in how big the Dahlgren looks!I think, realistically, that the bulwarks would be about shoulder height at minimum.
Oooh, yeah, more overall pics. I'm interested in what you've accomplished so far. Even with the sampling available, looks pretty tidy!
