OK, ladies and gentleman, If I can call you that....
First up today is repair of the motor power cord. So first step was to remove the black tape to see damage, then inspect wire to actual damage which looks like a not so friendly rat or squirrel might have nibbled on.
I think I had show the power cord and damage in another posting so here is repairs.
I stripped back insulation on cord till I got to damages spot, which exposed about 4" of wire. Then I measured what I needed from original ends for installation.
Next up was to cut and strip the wires and solder the new ends for installation in the switch housing.
then it was time to reinstall the cover and check how it fit and went together, all was well at this point with repairs.
Last but not least as another user mentioned, time to check the bushes for the motor, they have a nice cap to remove and then pull them out, they both looked good so careful install was done, as they are slightly rectangular, to not go back wrong. Just had to make sure I didn't have them 180 out. Fun with spring cap end, as it also only fit a certain way in and pop the cap on and finger tighten.
Last but not least was a quick test run and all was well.
