What a treasure!
That's for sure, Paul. And it's luxury large format with a hard cover. And for 'second hand' it's looking as new.What a treasure!
That's a nice new description, Grant. The journey to something is more important than reaching the destination.Good afternoon Peter. Your log is like a beautiful bike trip with something exquisite around each corner…..wonderful. Cheers Grant
Thanks for your visit and these very nice words, Johan. You are always welcome. (Other SoS members too, you know.)I was able to see her in the flesh today and, boy, what a model to behold!
It's a pity Peter's ideas on ship-modeling haven't attracted any trend-followers yet; I discovered I every much enjoy these so-called skeleton models and Peter's approach is very informative for those interested.
Thanks for your hospitality, the coffee and the delicious bokkepoot.
Thanks, Paul. Having reference pictures of the original Balder has its pros and cons. So far the advantages ........ but is has it's limits.Bolts and pins perfectly represented, Peter. A tour de force in precision modeling.
Thanks, Maarten. Vlaardingen is famous for its gigantic Japanese Saw ...........
Perhaps an inconspicuous rudder stop at mid point allowing your line work to be pulled taught?I still need to figure out something to tighten the lines a bit. Some clear varnish on them?
Superb adventure and pictures Peter, most interestingYesterday I had a pleasant day in the area where I grew up in my youth. An organization in Maassluis, together with one in Vlaardingen, organizes their so-called "Rondje Zoet en Zout" ("Fresh and Salt Tour") ...
Thanks for the idea, Daniel. I hope that the tiller and rudder remains there function.Perhaps an inconspicuous rudder stop at mid point allowing your line work to be pulled taught?
Awsome!
Thanks for the compliments, Pete and Mark.Superb adventure and pictures Peter, most interesting![]()
incalculable work!!!With the tiller still fresh in my mind, I set to work on it.
An overview:
With a bearing to secure the rudder stock, on top of that the metal tiller, with a wooden reinforcement at the end into which two large belay pins are inserted. And on de sides a single sheave blok.
Some details:
The bearing with pieces of hard wood on three sides, each secured with a wedge. On the inside of the bulwark is a metal bracket to which a single sheave block is hooked.
Various components are also detailed on drawings I obtained from the Amsterdam archives:
I have pasted two other details in the drawing of the tiller. Top left is the metal bracket with the caption "Brackets for steering tackle, 2 pieces."
There is also a schematic representation of "the steering system," with "circular tackle, manila 25 ø" and on the right side "block with becket and hook."
This has been adjusted on the Balder:
There are now two loose ends coming from the side blocks. Here, the skipper holds both of them in his right hand as we sail sharply out of Maassluis harbor. This puts a lot of force on the rudder. A moment later, he releases the port end and pulls strongly on the rudder, supported by the tightening starboard tackle.
This is how it turned out on my Balder:
Only the port tackle is reeved.
On the wooden end, the two wooden belay pins and on top, on either side the metal strips to prevent wear on the lines and block.
View of the bearing:
The three wedged wooden nuts are just visible.......
I still need to figure out something to tighten the lines a bit. Some clear varnish on them? On the other hand: everything is in rest.
It might be easier to leave that rig at rest, without tension, hanging... it's an idea.With the tiller still fresh in my mind, I set to work on it.
An overview:
Some details:
Thanks for this compliment, Shota.incalculable work!!!
