HMS ENTERPRISE by Keith 1:48 scale. New Kit from M.D.
Keef, you’re creating a beautiful piece of work. What craftsmanship you’re showing here. I certainly won’t forget your build log when I start on this kit myself sometime in the future. The same goes for the comments from the other builders who are adding to your report — it’s a wonderful complement to the construction manual. You can be proud of this.
For now, I’ll first focus on finishing my Victory.
Thank you for your comments. I'm really glad we can all be of help. Good luck with your Victory. I'm sure you will enjoy this one too
Richard,
I started building the Victory from Caldercraft almost three years ago. It's a fantastic kit with all kinds of beautiful materials. By now, I even make my own rope, and a few months ago I started working on the standing rigging. Feel free to take a look at my build log.
HI Keef hope you are feeling a bit better
think ive just managed to order a couple of pear sheets 2.4mm and 3mm hopefully ok
Wondering if i Should add some strip wood to go in between the FRames Are you using small square or Filling
For Keef, Corsair, or anybody else.
Gentlemen,since you are rapidly approaching the build for this question, Any thoughts?
I am progressing through instillation of all deck clamps…..lots of measuring, adjusting to get accurate. I go back occasionally to Victors
build photos and noticed a mis match between his build and instruction, specifically on clamp #8(thick) which is one of two that require #7/#6 clamps above and below for a three level clamp….l.one of two on the build.
His image indicates no instillation of #7, above the main clamp.
I reached out via PM to inquire as to why….oversight or some issue but this was several days back…..no response, thus the query.
In any event, i installed the 1mm #7 layer but still curious
P.S. got zero idea why the initial small text….zero idea what happened.
@TRS7139 What step number is this on? I'm still way back in gluing straight frames on the keel. :)
Unfortunately, I don't have an easy answer. It looks to me like either one could cause problems with the internal decks if you chose the wrong solution.
I think you should do some very careful measuring and use the solution that works out best with the internal decks. It's also possible that he left it off to make it easier to see some of the internal details.
No measuring needed after installing thick beam outlined in #41, both of the others locate off that.
The built up partitions sitting on the latforms have cutouts to fit around all three planks, thus, I installed them but still a divergence from plans which is why I asked Victor.
Sorry for the diversion.
Tim
Well, after taking another hard look at Victors photos, it looks like his build is likely a prototype and the lower deck beams don’t follow current instruction anyway so I went with the PDF instructions.
Pretty tedious process but everything came out pretty accurate.
Using the ply beam jigs allowed pretty accurate placement and beams, side to side ended up level. Have some final sanding yet to do but all in all I’m glad to be done with all of it.
Hi everybody. Apologies for the absence, not been too well. But now back in the workshop so hopefully can reclaim my build log back Have not been able to finish the hawse pieces so am filling in with work on the hull frames and gun port sills. Referencing the 1:1 drawing, I have taken the height measurements of every rib and transferred them to the model and have trimmed them all down to their correct heights, just the starboard side so far. Definitely improves the shape of the hull. Every rib had to be trimmed by between 3 and at most 6 mm
Welcome back. I'm looking forward to your work on the challenging bow...
Thanks Paul. I have completed most of the hawse pieces, but made a mistake in sanding rib no. 6 on the starboard side. As I cant scratch this piece, I have contacted M.D. for the replacement 2 halves, so at a standstill with this section of the build at present.
Good to see you back on the build of your impressive model, Keith.
