Thank you, Allan. I’m keeping my fingers crossed it all comes together. Adding an interior is new territory for me, further complicated by the addition of lighting.I love how you and others wire the models to shed some light in/on them, clever solution! I also like the reference to Baldrick. I've never seen Blackadder, but would love to give it a try.
What a brilliant solution! If I am interpreting this setup correctly, the whole ship is a switch, just slide it back a little and break the contacts turning off the lights.View attachment 546702
In order to wire the lighting for the ship before planking the hull, but still leaving the whole thing freely accessible as the rest of the build progresses, I am going to insert electrical contacts into the keel at the points where it rests in the pedestals. The pedestals themselves have leads soldered to the bases
One will connect to the positive side of the power supply, the other the negative side. The resistor and LEDs will be in series so wiring will be simple. I drilled holes for the leads next to the holes for the mounting screws.
With everything set in place, this is how it looks. No sign of wiring and the ship doesn’t need to stay permanently attached to the base.
With the contacts installed and the ship resting in the pedestals, resistance across the whole setup is effectively nil. I’ll call it a win.
Just waiting for some resistors to show up in the mail so I can test the lighting properly.
Hi, Daniel! That’s a very interesting idea, but I don’t dare leave Fair American loose with as much rigging as she’ll carry. I’ll install a switch in the base, but the ship will be screwed down securely once the hull is complete..What a brilliant solution! If I am interpreting this setup correctly, the whole ship is a switch, just slide it back a little and break the contacts turning off the lights.
My Bluenose just sets loosely in its pedestals which so far has not been a problem.
Thank you, DD! I’m glad you’re enjoying them.Super cool!!! And the commentary and memes are entertaining as always. Thank you!
Thank you, my friend!Hey Namabiiru,
really very well thought out. I'm really happy for you and I think, just like Mellpapa: great work!
I'm already looking forward to the next pictures.![]()
You flatter me, Günther. Neither my modeling nor my photography are particularly noteworthy, but I am appreciative beyond words for your encouragement.Hey Namabiiru,
I'm already looking forward to it ... and above all to your great photos ...![]()
Me too! My Dad is an expert with this stuff, but I just watch YouTube videos and cross my fingers!The electronics are fascinating to look at; I can only marvel at how they actually work.
It’s all low voltage past the wall wart so no risk of that. I certainly hope it all looks good when everything is finished.If I tried those wiring mods there would be a Viking funeral...
Thank you. I think you’ve sufficiently shown that you’re adventurous enough to try whatever you set your mind to and clever enough to pull it off. I’m thinking glowing red piñata eyes (next year)…Seriously impressed by the electronics! Nicely done. One day I won't be too intimidated to learn.
Ah, you underestimate my level of electrical incompetenceIt’s all low voltage past the wall wart so no risk of that.
