HMS Enterprise 1775 1/96 - First build log
OK Allan I will try it on a test piece. I need more guidance though. I imagine the correct size would result in an attractive 'slender' appearance, but I'm not clear about the rate of taper e.g. If I do so, how 'thick' should the upper and lower sills be for the gunports? Upper sills around midship might be very thin.
The contract that you have gives the moulded dimensions at each end of the floors and most of the futtocks so you can see the amount of narrowing each frame does in the in and out direction, It is gradual unlike the stepped reduction in the sided direction. The sills will be the same dimension as the in and out/'moulded dimension of the frame at the point where the sills are set in place. I hope this makes some sense, because as I read it back, I am not so sure.
Thanks Allan,
I get it. Time to delve deeper into the contract.
Margin planks, riding bitts?, and the first of the hatch combings fitted. I plan to make gratings (following the method illustrated by Mustafa's brilliant USS Constitution build log). If successful I'll use it for some of the other hatches on the lower deck to create a bit of contrast and variety. The supplied gratings in my kit are very burnt and not really to my liking. 20251009_124045.jpg
Probably not super important, just an FYI for the future, the head ledges sit on top of the coamings. Hard to tell from the photos, but it looks like your coamings are on top of the head ledges. Also the corners above the level of the deck planks were usually rounded off.
Hi Allan,
Yes I'm following the 'instruction' or plans for the model which are not clear. On the upper deck I'll see what I can do, but the pieces are 1.5mm sq and the wood is a little more brittle than I'm used to.
Rounding the corners will be easy, but the correct joinery at 1:96 is beyond me and may not be noticable. I tried beading a knee and that wasn't worth the effort.
The supplied gratings are not usable, and when I tried to fabricate my own it just didn't look right. The model, as I am making it, is focussed on the major structures of the ship and not soo much on the fittings and details. I'm undecided about pretty much every aspect of it until I try things out. Some thing look 'right' to me, and some appear jarring.
Makng proper gratings at 1:48 requires specific tools and it is not the easiest thing to do. At 1:96 it can be even more difficult. The main things for the gratings are the openings are no more than about 2.5" to 3" square and the battens run (or appear to run) fore and aft, not athwartships.
It wasn't so much the manufacturing process, which was a challenge as it required 0.75 mm openings, it was the aestheics.......
The model is developing as a collection of large scale perpendicular shapes. These are in a sense surrounded by the hanging, lodging and standing knees, which add curvature and 'frame' the structure, along with the gentle curve of the hull. In my opinion, the fine detail of the gratings broke the visual cohesion. I placed the figurehead on yesterday and, again in my opinion, it had the same effect. If I added more fine detail across the entire ship it would be more 'balanced', but I'm going to stick to a minimalist approach. for the moment at least.
I rather enjoy the challenge of balancing historical accuracy, precision, aesthetics and practicality, but it does slow me down as I mull over things for long periods.
Allan, I also have a question about the mast steps, which are missing in the kit. Would the following drawing be accurate?.....
the second image is the mizzen step as installed by the manufacturer on a prototype.
Image 3 is my current progress in the bow region. Drew a sigh of relief when the bitts lined up between the orlop deck, lower deck and upper deck.
T
First, your build is spectacular, congrats!
Mast steps were pretty simple units at the time of Enterprise 1775 but sometimes sat differently depending on the size of the ship and the era.
Sizes are easy.......... From the contract:
MIZEN STEP ….. The Mizen Step to be sided 14 ½ ins, of sufficient Depth on the Keelson, The Arms 5ft 6ins long each, & bolted with 6 bolts of 1 ⅛ dia'r.
MAIN STEP ….. The main Step to be sided 1 ft 11 ins and 15 ins deep on the Keelson and of a length to slide easy by the Stantions of the Well.
FORE STEP ….. The Fore Step to be sided 1 ft 9 ins, in Length 10 ft 6 ins, bolted 6 bolts of 1 ⅛ dia'r
Keep in mind the main mast step is wedged in place so it can be moved fore and aft to adjust the rake of the mast. For the foremast step, it sometimes sat between two crutches, but from the original plans it appears this was not the case. I did just now notice that the foremast location was changed from the original location but I only have the low resolution plan so cannot make out the notes about this.
The mizzen step was sometimes also part of a crutch, but does not appear to be the case for Enterprise. based on the contract which indicates one crutch and is separate from the step.
CRUTCHES In HOLD To have 1 Crutch in the Run Abaft the Mizen Step, sided 9 ins The Arms 5ft 6 ins long, & bolted with 7 bolts 1 dia'r.
Main mast step with wedges
General shapes of foremast step and main mast step. As the foremast step on Enterprise is not bordered by crutches, I would go with the same basic shape as the main step. Shaping it to fit the is more of a challenge than the main mast step, but it helps to start by making a cardboard template based on the body plan drawing. It will get you close but then it gets to be fun getting the exact shape. Ignore the dimensions in the drawing below as it is from Trincomalee, but the shape is typical. The following is from Peter Goodwin's, The Construction and Fitting of the English Man of War.
Thank you Allen for your appreciation and that comprehensive explanation of the 'way of the mast step'. I'll be working on it soon because I should have done so before completing the lower deck and it already requires a fair bit of keyhole surgery.
I think with the well in place it would be nigh impossible to have the wedges set up for the main mast. Maybe just the step itself or fake the wedges by gluing them to the fore and aft side of the step before putting the whole thing in place over the keelson.
I am happy that you found the information useful.
Started this Modelship Dockyard project about three months ago, but was never sure how it would pan out, so only just starting a log.........................
The early stages, making the frames, seemed tedious and I wish I'd done a better job. The rough fairing has already involved removing more material than I'd like, but I have learnt my lesson. Way more care to be taken next time!
Finding parts is a challenge and looking at other build logs here on SOS has been indispensable. The kit's instructions, excepting the eight videos, are minimal and some kit parts are missing or so similar as to create some confusion. Various gaps and misalignments have appeared during construction which take a little ingenuity and head scratching to resolve. However, that’s been part of the fun of it.
Current status seen below. Just finishing the lower deck. Next step standing knees and hatch combings. I will probably do a little more of the rough fairing as well because I'm concerned that heavy vibration later may start to weaken joints on some of the more delicate parts where the wood-to-wood contact area is very small. Boxwood is hard, and many parts are very thin, so vibration is considerable.
I've left out various elements, such as the interior rooms as I wasn't thrilled with the laser engraving quality. I also felt that I wanted to 'open out' the interior and let in more light. Furthermore, I used thinner stock for the carlings for the same reason. I removed most of the engraving from the 'well' due to its boldness. I wanted to include the well as it's a nice connection between the frame and the lower deck and its central position just sorta works!
I'll not be using any of the 3D printer parts as I want the model to be just wood and glue. Some I'll remake in boxwood, others I'll leave out. It all depends on visual effect. My idea isn't to make a perfectly accurate model, but a visually interesting representation of the ship that shows of the natural beauty of its design and construction as well as the quality of the kit.
No liquid surface treatment to be used. All finishing is with polishing paper which is very laborious, but I like the look of natural wood.
View attachment 548615View attachment 548616View attachment 548617View attachment 548618
Richard, if you ever get to Bristol, there is a model in the museum there of HMS Medea, an Enterprise class 28. I haven't seen it myself but have photographs and a book about the builder (of the ship and the model). I can send more details if you want.
Thank you Ian,
I'm very interested in seeing more details.
I've looked at your excellent Medea scratchbuild several times on SOS. I'm finding it very informative. I am somewhat overwhelmed by the amount of skill and knowledge a project like your's requires. I am basically a miniatures woodworker who likes to think that I am working towards a scratchbuilt vessel in the not too distant future. However, here is still a lot about shipbuilding I need to research and learn.
