Pavel Nikitin Oseberg #3 kit #61
Great accomplishment Jan, that's one area I'm not looking forward to.
:rolleyes: I put that little chore off for quite awhile but finally had to get it done. I did wear a mask and a big apron. I did them by hand sanding versus using a little drum sander to remove the char. I was afraid of breakage while removing the char and then shaping them.
Jan
I've spent the last couple of shipyard sessions completing the small bits, fixing odds and ends, camouflaging mistakes, errors , etc.
Since I added the modified mast step and deck kit. I have a question.
By moving the mast step forward one section I've changed the rigging pattern.
The above (arrows) show the the cleats as per the rigging plan, With the new step in place should I redo the aft and forward cleats by moving them forward one section or leave them as is and do the rigging as shown on the kit plan.
Jan
Jan
Good morning Jan. Nice- very nice. It is a cool looking model. That is always the problem when we correct a kit - the knock on changes never seem to stop. Cheers Grant
Hey everyone.
I agree. I'm currently removing the rust marks from the HMS Enterprise. It's really time-consuming. Unfortunately, I can't remove them all because the kit has such tiny, delicate parts and I'm afraid of breaking them...
Jan
Jan, while I'm not there yet, it would make sense to me that anything connected to the mast should move forward with the mast - at least that's what I plan on doing. Here's a drawing from Dr. Bischoff's dissertation showing how she believed the rigging looked. This illustration should also be in her book, but it's not with me here at work to check.
Thanks I don't know why I didn't think of that (Cognative Process is not what it was). I have her Thesis saved as a PDF and will check it out.
Jan
A little Re-Do project.
I wasn't happy with the S'board fit of the Shield Plank. I didn't get a good glue result placing it against the hull. The stand-off pieces
that go-between the rail and the hull are very small and tended to break away from the hull when I handled it (Big Fumbly Fingers). I removed the plank and redid the stand-offs with 4X4X4mm pieces. Gluing those to the plank and then to the hull worked out good.
I had no trouble placing the shields.
Tomorrow I'll start a Re-Do on the port side.
Jan
(:( Winter has arrived early, ten inches (4cm) of snow yesterday and the current temperature at 10:20 PM is 12F/-11C with the wind gusting at 20+mph)
