Yesterday I said that I would not be making a real differential, well I lied. I decided to try and see if it could work. So today, I designed the internal components that makes a differential do what it does which is to drive both wheels while permitting the wheels to rotate at different speeds. It's a beautiful feat of engineering invented back in 1827 by a French guy named Pecqueur.
I also redid the half shafts with more accurate universal joints along with the drive shaft. I incorporated the small bearing (which I received today and boy, are they tiny) in the front hubs. I had to find slightly larger bearings for the differential, I went with 4mm id instead of the 3mm id used in the hubs.
Redesigned half shafts
Differential internal bits
Working differential (in cad at least)
View attachment 20251117_194827.mp4
