Your bowsprit rigging look so real…..you are owning this.
I had the opportunity to see this model in person, and the aged appearance is masterfully executed and extremely realistic. The photographs do not tell a false story.
Good morning Erik. Wonderful detail on those mast tops. I see you also went for the solid tops vs the grated tops which I believe were introduced when they changed the HMS Bertha to HMAV Bounty. Cheers Grant
Perhaps I will indeed try to explain how I age my wood. It's not really that complicated. With the right choice of wood and then the right stain and oil, a lot can be achieved.Indeed, your aging and weathering technique is masterful. That would make for a great tutorial series here on the forum (hint, hint).![]()
That's right, Grant. Although the tops of the Bethia have indeed been replaced by gratings, I also made the tops solid. The gratings from the kit were of such poor quality that it was impossible to make nice symmetrical grated tops.grated tops which I believe were introduced when they changed the HMS Bertha to HMAV Bounty. Cheers
I'll add my vote for information on how you achieve the wood finishes and patina on your model. It is extremely well done and lifelike, probably the most realistic I've see. Excellent work!!Thank you all for these nice comments!!
Thanks a lot! Great compliment!Truly outstanding ropework! Wow! This is not just next level, it's top level.
Thank you too, Paul! I did indeed start with the Artesania Latina kit as a basis.What a great set up upgrades and customizations to what I suspect is a rather ordinary kit offering from AL.
Thank you too!I'll add my vote for information on how you achieve the wood finishes and patina on your model. It is extremely well done and lifelike, probably the most realistic I've see. Excellent work!!
Thanks mate, I did not guess at all.
