Сестрорецк [Sestroretsk] Scratchbuild scale 1/64 Russ. torpedo boat 1894
  • Thread starter Thread starter Iterum
  • Watchers Watchers 8
So everything is copied and these are fitting in scale to 1/48 and to each other. I didn't got a scale gauge with the frames so I looked on top of the light tablet for the spacing of the water lines.
For better detailing I enlarged one set of drawings of sideview/WLplan by 150% up to 1/32 - I ever become as made as to build her in this amazing scale:
Tbc
Сестрорецк [Sestroretsk] from 1894 has been upscaled to 1/32
to redraw the old plan from ink on linen fabric in a propper way. Let's start finding the details.
The other copies in 1/48 are ready for glueing on cardboard (trying spray glue for a dry contact) and cutting out:
So building will start in 1/48 this evening...
First decissions for the build are made:
1ST
So there will certainly be the CenterBoard and to get mir "stiffness" I do add parallelly the vertical layer N°II or N°III as I do habe to build the centerboard from a number of cardboard pices.
The decission about the position of the vertical layers will depend on the results of a test build of the midsection.
2ND
All the underwater water lines will be brought in so the underwater hull has has a good "definition" - they will be simply pushed in horizontal slots.
3RD
The bulkheads will come with a CL-slot from below and a pair of N° II or N°III slots from the top. The "planking" will be made by some 160g paper.
4TH
But the imitation of the plating depends on the thickness of the original plating I do hope to find in the cutting drawings.
Does you have any suggestions to my four points?
Irritation -
the lines drawings were SEVEN MILLIMETERS shorter than the other drawings in the very same scale.
So I decided to cut the plan into two parts at the less to beavel part surrounding the engine room.
So this problem ist"fixed"
Today there were good and unnice results with the water lines drawings:
...and the result was terrorising because the hole CL wasn't straight at all :eek:
...so I decided to redraw the lines drawings and prepared all needed materials for tomorrow - and put alongsite the CL.
Good results were made at the CL onto two sheets of DIN A3 papers - there it all fits in (but not in the copyshop due to the framing around).
All the formers are cut out - and so I can add all the waterlines in the WLdrawing. So tomorrow I have to Work with my big taylor's rulerset.
Today the waterline drawing have to be
"repaired" here my way to deal with this huge Problem:
I.
Due to get a correct result I have started to put the bulkheads cutouts onto the yesterday drawn centerline (CL)
and punched thought the copied bulkhead's line with a fine cutter's tip - so getting a precise point to run the waterline onto - hopefully...
II.
So to avoid any sinister inconsistancies I only
set the portsided dots and so I have an easier time.
III.
When all the portside dots are placed than I will take a pair of compasses to mirrow them ontop towards the starboard side.
So that's all from me the cardyard and this finscale work being very annoying to my eyes...
BTW
...and due to this dotting technique good old punched card ist back again!
Hello,
the SESTRORETSK made a good progress today, I got the two part centerboard drawn ready, cut out the straight section of the keel.
And decided to keep the staircase's upper structure in the centerboard.
Hello friends,
today a good step forward was made,
most of the CenterBoard was cut out.
IMG-20251127-WA0003.jpegThe slots for the stanchions of the stand were drawn in, and the bulkhead's slots we're scratched in.
So a very small edge of the third dimension was hit:
Thank you very much for your interestin
g, CHP
Hello friends of the cardboard,
Today a bit of progress was done - cutting the bulkheads' slots into the centerboard.
The first testfit with the bh-19 fits quite
es well
Than I added 266,6mms of the Lpp from both sides twice a 5,0×45mms slot for the stand's stanchions prepared for using a five millimeters brass pipe:
Then doubling the centerboard in thickness - up towards 4mms - so it is stiffer and is not longer seperated in a short aft and a long bow part:
That's all for here and from me,
CHP
...here my drawing for the stand (will be enlarged in the copying machine).
I did look for Russian Art Noveau letters for the stand and search for inspiration online.
Perchance you do have some ideas for me?
I did look for Russian Art Noveau letters for tshe stand and search for inspiration online.
Polish_20251203_215421616.jpgPolish_20251203_215542249.jpgScreenshot_2025-12-03-18-35-25-369_org.telegram.messenger-edit.jpg
Hello friends,
so today I worked with the doubled centerboard cut the next 2mm into shape
IMG-20251204-WA0004.jpegand "hardened" edges by the use of cheap superglue:
At the end I cut out the needed quater the stanchion bulkbeads, the part below the CWL to get a 1:1 drawing for the bow and aft stands:
So for the weekend I will Deal with Art Noveau and my stand - hopefully.
Hello friends,
I found my removal box with plan sets and in there is a plan set in 1/50 of Пернов PERNOV an other torpedo boat built by Normand from Jan.1891 untill Nov.1892 - so a good source I do hope...
In there I did find a plenty of great details of typical Normand's charakter - like the hatches' types
or the wheel.
The screw is ab very important pice of document to me.
So here some pictures to show the found treasure to you.
Hope it is not too boring for you, CHP
The first scetch for the stand becomes ready - it is a long way to go, but a reasonable start is made:
Here my First Trial in 2mms bookbinder cardboard and simple Xerox paper:IMG-20251208-WA0021.jpeg
