Beautiful job Loracs!
That looks very nice, Loracs. A great job!Frames to the keel: the first 49 frames are now glued to the keel. Will complete the last 6 once the glue has a chance to cure a little.
View attachment 565144View attachment 565145
You did a fine job, also with the parts at the bow and stern, Loracs. After starting with the sanding she is showing her lines very nice from bow to stern.Front and back hull: Let me say that there is no easy way to tackle those two areas. You need to carefully sand those tiny pieces and dry fit over and over... and more. They will test your patience. They are difficult to both fare and glue in place. That completes the hull for now.
I did a first pass on fairing the hull (still dusty). The outside went very smoothly. The interior is more challenging. It is hard to get into the small space.
Well, this is it for now. Happy holidays all!
View attachment 566034View attachment 566037View attachment 566035View attachment 566036
I had done a poor job of building the transom section and when I attached it to the aft end you can see how uneven the the individual pieces are. In addition to that they were not in the same plane as the two center pieces which were part of the main assembly.@Daniel20, thanks a lot! but you are selling yourself short... ;-) Happy Christmas.
Edit: I look back at your log; it was indeed quite nice. Now, my question: did you broke the back area at one time? I just saw a little crack. That repair was outstanding. That made me realized that I did a small mistake... I sand off the 1mm protruding of piece #53... oops! will be an easy fix thought with a 1mm plank.
I made the same mistake. A 1mm strip makes a good recovery.Unlike as the documentation suggested, I mistakenly placed the 1mm overhang on the inside rather than the outside. No big deal, I can correct by adding a 1mm strip to this area.
Ditto!Excellent job! Way better looking than my start.
Judging by your homemade 3 axis milling machine and your other innovative ideas, you have passed way over the bar and are ready for the Olympics!I'm just trying to pass the bar. ;_)
My BN-build was definitely a very educational experience. It's a kit you can build from the drawings and the build description, but it also allows you to step beyond and add some details here and there to make it your own personal rendition.
