- Dec 13, 2025
After sanding and oiling, only dark stripes will be visible.
Concerning the “piracy” issue, this isn’t something we have authority over, nor is it our field of expertise. Before "tagging' someone with 'piracy, it’s best left to those who truly know the subject. I’d rather see the discussion return to modeling, where we can all contribute meaningfully.As far as the so-called "piracy" issue is concerned, I will let @Jimsky address that. He has a special and polite way of doing that - I am far too direct!
This appears quite salvageable. Don't sand in a cross-grain direction. Sanding those cross-scratches out will be some work. I suggest you use a razor scraper to scrape the deck until those scratches are removed. Take your time and scrape in slow, even, overlapping strokes. Scraping the deck smooths it and evens out any offset planking seams. It will look BETTER than sanded. Use sanding sticks to get close to the bulwarks and in corners and always sand along the grain (fore-aft). After that, finish the deck with oil or varnish and you're good.This is how it turned out. I don't like it. I'll have to redo it.
The wood used to frame the gun ports on your model does two things. 1) It makes the hull appear thicker on the model, because you will not be making the interior planking. 2) It supports the ends of the outer planks around the hole of each gun port.I don't understand the purpose of this design at all. None of the authors (Hoving, Laveri) have it. It's in the drawing from the kit. If this is historically accurate, it should be done. But this detail won't be visible on the model. Maybe we can do it this way? And it would be easier to correctly set the distance between the gun ports. That's strange. They differ in the drawing. The documents provide precise data between the gun ports depending on the gun caliber. They should be the same.
