Bluenose I - YuanQuin 1:72 - Loracs (in progress)
Loracs, your work on the substructure is outstanding. It will serve as a great foundation for any type of mods you have in mind however be aware of that which Johan @RDN1954 mentioned in post #144 of your build. Certain deck openings are located directly over interior support foundations which you would not want to cover or modify.
Indeed, this area is keeping me awake (figure of speech). I'm hoping that I can get by without the support foundation by relying on the ~ 5mm depth main deck beam to anchor the deck structures (making square channels - 4 to 5mm deep with flat bottom). Will have to look closely before committing in that direction. Will keep the option of doing YQ under-platform until I know for sure.
Bow lower platform/floor: I cut and sanded the support beams at the bow. I adjusted them to be 3 mm above the last middle beam. The transition step is then at frame 13. Based on the following measurements, I should be able to clear either 4 pairs of bunkbeds or 3 pairs + single.
Bunkbed dimensions: Navy std = 72" long x 30" wide x 17" height. This translates to 25 mm x 10.5 mm x 6 mm
Bow height across the floor: 21 mm at the middle to 11 mm at the bow. The height should barely clear the be
Overall room: the wall will be located at frame 15, nearly 135 mm away from the bow. That should give some flexibility in fitting them.
Lastly (unresolved): could the beams/anchor points coming down from the deck (YQ design) be incorporated within the design? Maybe some of them... NOTE LATER: won't really fit with the bunkbeds. That's OK. The small spacers pieces can be used later within the main deck for reference and anchors points at the bottom of the beams. 4-5 mm should be enough to stabilize the deck components.
Stingers: Stingers installed. They are build from a 3mm x 2mm strips, then shaped at an angle. It's a slow process... One last set of support beams to go: the captain's cabin floor. Will shape then but may wait until the ceiling is planked. It seen a lot easier that way them planking around them. Will see...
It is amazing how wood gets stained fast, despite working with gloves 95% of the time, which I hate!
Bow floor support beams: This is what they look like, glued in place. As you can see, they are a lot lower than outlined by
YQ since this will be a floor rather than a support structure. Build using 3mm x 1mm strips and again shaped at an angle.
Mast support blocks and water wells: Taking a short break... so doing only a few little things here and there. 2x zoom picture is very unforgiving - will need to quickly sand with a higher grit. Main mast support block needed some tweaking to account for the sister keelson... I knew it was coming but a little tedious to do manually (and straight). Water wells are finally glued and ready to go. Adding bolts is now less stressful with 0.6mm carbide bits - they stay sharp and with a mini-drill press they don't break - I'm still using the same one from when I started the interior.
Pig iron as ballast: Pig iron can vary quite a lot in size. The smallest are 140x140x70mm, medium 200x200x100mm while the largest can be up to 280x100x65mm. At 1/172 this is roughly 2-4mm irregular in size. E6000 as glue is ok, but the chemical smell is quite bad. I tried Frabri-Tac because the solvent is acetone, a less aggressive smell and can be diluted to the consistency you want while still drying fast. Here's a quick test:
Captain's cabin floor: Installed the support beams for the captain cabin floor. Getting it to be at the proper spacing and parallel to the waterline is an exercise in patience. Installing the support beams now will allow me to build the inner platform (floor) like the rest of the ship.
If memory serves me correctly, I extended the Samson post to the keel, more or less like the sketches in the Saga. The other bits were shortened as not to protrude into the focsle.
A lot of detailed work, which is hardly visible after completion. Still very rewarding, even though others wouldn't be able to see it.
View attachment 571752View attachment 571753
When all the pre-work is done, the fun begins, Loracs. But this part of the construction must certainly also have been satisfying.
@RDN1954, I was indeed wondering about which parts to extend and which to shorten. Thank you and @Daniel20 for the comments.... this will help at lot.
@Peter Voogt, I'm really enjoying the build. I try to take it slowly and not rush into committing decision. This is when I make mistake(s) that can hardly be reverse. Building model ship is like savoring a good wine or beer... why rush it. In short, I procrastinate a lot (Hehe). I like reading about the thought process and implementation many, including yourself and RDN, have done at improving the kit. It goes beyond just mods... it became learning moments.
Interior - Planking ceiling: That was a challenge... you have to account for the existing support beams and later the crossbeams. That a lot of adjustment as you planks. Basically one strip at a time, tweaking as you go. Not perfect but acceptable. Time to think about the nails... hum!
I decided not to do the platform across the stingers. The captain cabin (floor) is taking a lot of real estate already. I'm not sure that a secondary floor directly underneath make sense, since the headroom is only few feet (3-4 maybe?). I think the original design will have maximize space and kept this area for miscellaneous storage (nets, ropes, wood planks, etc...) since it is right beside the cargo area. Here we go "creative license" without more information, nobody knows.
Masts, Water Wells and Ballast: Final elements at the bottom of the ship. It is nice to have the masts pre-shaped. However, they are cut to exact length... so no room for mistake when making the square end. It is always nice to see the ship developing with the addition of new elements.
I wish it was my idea... I saw it in a few build logs for the Bluenose. I thought too that it adds a little bit of realism. This is the advantage of coming late to the group build, you have the opportunity to incorporate several ideas/mods from previous modelers.
View attachment 573662View attachment 573663View attachment 573664View attachment 573665
Nicely executed details with those nails, water wells, mast steps and ballast, Loracs.
Ceiling Nails and Treatment with Linseed Oil: I'm assuming the internal planks would be done with metal nails without covering with wood. I may be wrong though, this is just a guess. If so, they would be quite small at scale - in the 0.1 to 0.25 range. Therefore, nails are simply done using a fine needle. This is my first time doing so, and made few mistakes along the way.
Linseed oil brings out the wood color so nicely... pleased so far.
Small update: I have not made any progress this week. I have been quite busy with another task... learning a CAD software. I decided to go with Autodesk Fusion 360, a commercial application for parametric design, assembly and plan drawings. I'm using the personal (non-commercial) edition, a completely free license. It has a steep learning curve, but the overall interface is quite nice. I will be sharing my project at a later time in another post. I'm likely back to the bluenose very soon though.
To the best of my knowledge, there's no such thing as an easy to learn 3D CAD software. A while ago I evaluated both FreeCad and Autodesk for personal use.
The decisive characteristic between the two turned out to be the number of documents one can store. For Autodesk that number is ten, which is for my current project way too few. FreeCad doesn't have this restriction.
