Proxxon MF 70 | Upgrade Tools Jigs Workspace | Making: grating ladder stair skylight pin carriage pump windlass winch mast yard
The LED ring light is quite large I agree. I looked around but was not able to find a smaller ring light that would fit onto the bottom of the mill body (36mm diameter). I don't know if the sewing light would fit but if it does, it looks a nice cheap option. I tried using some small LED spot lights on flexible stalks to light the work area but I found that the lights just got in the way and cast shadows so you really need to light directly above the cutter. If I find time I might make a custom LED light myself as a little project.
By the way, I was also thinking about making my own lamp, but I think I'll test the sewing machine lamp and if it's not so good, I'll make a custom one based on it. The price is good, even if I have to remake it later. There are better options, but they're х10 more expensive.
I dug up a cheap, small, LED goose neck desk lamp, seems to do the job without getting in the way. Old school + LED brother. I'm sure it will be plenty dusty and greasy soon enough.
@piter56 @glennb17 @GIG1810
Thanks, friends. These are good options.
This link shows, in three parts, how to make a grating like this step-by-step.
The difficulty with this lattice is that not only is there a cut-out in the side sections, but also that the longitudinal and transverse slats are not the same thickness. Some are 1 mm, while others are 0.8 mm.
In the link below, I show step-by-step how I built this Skylight (companionway to the captain's quarters) for my cutter on a Proxxon MF 70 in two parts.
But the technology is applicable to any similar design on any similar ship.
Just a quick update regarding the light. Nobody sells the Proxxon light in the UK and shipping from a European supplier made them too expensive. I looked again and found these Angel-Eye lights on AliExpress which are perfect. I bought the 40mm OD version which is 12V and works on the dimmer that I already have. Paid £1.60 for the light! Very thin and compact and I used some double sided tape to stick the light onto the mill.
Thank you, this is a very interesting option and, most importantly, very inexpensive. You just need to wire it to any 12V power supply.
Have been admiring your work on HMS Alert - really impressive, and understand you have been using the Proxxon MF 70 for some of the work. I see that you have changed the bearings with significant improvement in the machine. Other users of the Proxxon have changed the collet and spindle to enable use of wider shanks. Have you done this on your machine as well? Or have you not found it necessary?
James
James
Thanks for the feedback. I haven't needed it yet. I'm currently using factory parts for everything I need, but that could change if necessary.
Gangway (companionway to after platform)
The link below shows how to make this design on a Proxxon mf 70.
Lower Deck Gratings and Hatches.
Making a regular Gratings without cutting into the sides.
Another way to make a complex Gratings with cut-outs, but with a more accelerated technique.
Rudder feather.
Bowsprit Pins.
Bitt Pins
As an added note to this thread, I just last month got my MF70.
The Z axis is not bad to move up and down. However the X and Y are another story. They are much more difficult. So, I'm going to upgrade all 3 with the bearing upgrade shown. Going to work on it in my shop now. :)
All 3 axis upgrades are done and it is a huge difference ! Thank you Serikoff and Jimsky for posting these great guides ! Thumbsup:D
when you say huge difference do you mean the axes wheels turn a lot easier? I am thinking of doing the same upgrade, but I am not sure
thank you
