After posting a picture on rounding axles a member had the idea of a thread with little "how-to" items or tricks of the trade that might be of interest for both kit and scratch builders.. Hope this is of interest for one and all to contribute their little tricks.
If this subject has already been started, please let me know, I looked and could not find anything.
First up
Rounding truck axles on cannon carriages. Too many times we are relegated to having axles that are not round. To round them by hand is tedious and not consistent but I came up with a little device some years ago that is simple to make and easy to use .
Take a small piece of brass or aluminum rod and drill a hole in one end that is the diameter that is needed. Typically the width of the trucks is the same as the thickness of carriage brackets and the axle diameter is about the same as well. Once the hole is drilled, make a couple cross cuts with a hack saw which will create cutting edges in the drilled hole.
The axles were not usually square so you will feel the cutter stop when it hits the shoulder which takes a second or less in time. It may take a little cleaning up of peelings. If they are square, a little care needs to be taken not to round too far down. Marking the cutter with ink or tape as an indicator is easy and effective.
I cut a piece of PVC pipe to be a little over 24” (longest length of planks I’ve encountered so far) and glued a cap to one end. I fill it up and clamp it upright to the side of the bench. The planks float so I can use it with shorter planks too. I have another cap to put on top to keep the planks submerged.When we plank our models, for bending the planks many of us soak the plank. Well I wanted to come up with a way to be able to soak a pretty lengthy plank that didn't take up a lot a room and wouldn't use a lot of water but still large enough to be able to support a pretty good length of wood. I wanted something that would be upright rather than take a lot of space on the workbench or whatever surface and I found various graduated cylinders. They come in various sizes and you can get them in plastic so it eliminates the risk of broken glass and they are relatively inexpensive.
I picked up a couple of sizes. the 1000ml (the bigger of the two) is about 3" in diameter and just over 16" tall.
The 100 ml is 1.25" in diameter and just under 10" tall.
Its not a problem to get the wood out because the wood floats in the water so its going to be at the top.
Hope it helps someone.![]()
Same here. I have a couple shorties and a longer tube. I sometimes attach a cap to the open end (without glue) as I have been known to knock one over, spilling water on the work bench or floor.I cut a piece of PVC pipe to be a little over 24” (longest length of planks I’ve encountered so far) and glued a cap to one end.
Small parts and Cheerios…One of my best tools for small parts. And it saves my knees. Play tack on a 4' dowel.
Hi Allan, So I done my sums with the Bounty and worked out the main mast diameter is around 480mm. So, we say 0.62 of that is 298 mm which we divide by 48 (The scale I am doing the Bounty at...) and we get 6.2mm Rope for the Main? anchor. Don't seem right to me or have I got it wrong?Hi Paul,
For the anchor the following are from Lees Masting and Rigging page 188.
Sheet, best bower and bower anchor cable circumference is 0.62 X the diameter of the main mast.
Kedge anchor cable is 0.6 the size of the sheet anchor cable.
The spare cables were an inch or so smaller in circumference.
Other anchor rigging
cable messenger 0.75X main stay
Cat falls and cat head stopper 0.33X the main stay
Shank painter tail 0.4 X the main stay
fish pendant 0.5 X the main stay
fish pendant tackle 0.25 X the main stay
There are several other ropes concerning anchor handling related items as well.
Hope this is helpful.
Are you getting diameters and circumference mixed up ?Hi Allan, So I done my sums with the Bounty and worked out the main mast diameter is around 480mm. So, we say 0.62 of that is 298 mm which we divide by 48 (The scale I am doing the Bounty at...) and we get 6.2mm Rope for the Main? anchor. Don't seem right to me or have I got it wrong?
Hi Gary,6.2mm Rope for the Main? anchor. Don't seem right to me or have I got it wrong?
No guys, look at what is written and stated here on the next line as written:Are you getting diameters and circumference mixed up ?
The circumference of a circle is Pi x D (or 3.14 x diameter) so a rope with a circumference of 6.2mm would have a diameter of 1.97mm so 2 is perfect!A scaled rope with a circumference of 6.2 mm has a diameter of 2 mm which should be just about right...
Or maybe I'm missing something?
